Finish my paint job
Old 02-27-2017, 11:15 AM
96halfton's Avatar
96halfton
96halfton is offline
Finish my paint job
Finished my tremclad paint job on my truck. I painted it with gloss black and aluminum useing a spray gun. For paint that is $50 a gallon I think it turned out great.
No more rust!
Old 02-27-2017, 01:53 PM
Dogsoldier808's Avatar
Dogsoldier808
Dogsoldier808 is offline
Cool, that looks like a nice finish!
Old 02-27-2017, 04:55 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Now you just need to wet sand and buff it to get rid of the orange peal
Old 02-27-2017, 05:06 PM
96halfton's Avatar
96halfton
What exactly is orange peel and if i sand it won't that take the shine off the paint?
Old 02-27-2017, 05:54 PM
Diesel_Brad
Orange peal is texture, just like an orange skin.
Sanding will take the shine off and make it flat(shine and texture) buffing it then brings the shine back
Old 02-28-2017, 11:27 PM
96halfton's Avatar
96halfton
I see what you mean. I was thinking of putting some clear coat on it as I found tremclad clearcoat in spray cans. Could I sand it out and then use the clearcoat to get the shine back? If so what grit of sand paper would I use? I am guessing somewhere in the 1000-1500 range?
Old 03-01-2017, 07:27 AM
Diesel_Brad
Well if you want to clear over top of what you have you first need to sand you base color with 1500 grit paper. Then you can clear over top. But I do NOT recommend trying to clear coat large automotive panels with a spray can. it dries too fast and it will look like hell.
Old 03-01-2017, 07:39 AM
Christian's1988Ford's Avatar
Christian's1988Ford
Christian's1988Ford is offline
Sand with 1000 grit, followed by 2000 grit, and then use a Ryobi buffer with Meguiar's Compound (found at Walmart).
Old 03-01-2017, 03:22 PM
96halfton's Avatar
96halfton
Ya I imagine the spray cans wouldn't turn out too well but I can't seem to find tremclad clear in quarts or gallons. I don't think that regular clear coat would work well with the oil based tremclad. I'll probably try it out on the tailgate as that has the worst orange peel and I can easily repaint it.
Curated Content Editor
Paint & Bodywork
12-27-2019 03:14 PM
AK Adventurer
39
06-07-2018 10:59 AM
2fifty
07-31-2017 10:15 PM
harrelle
26
07-03-2013 07:32 PM
clindahl
Paint & Bodywork
08-09-2011 10:11 AM
Quick Reply: Finish my paint job
