Symptoms of a throttle position sensor going bad? - Page 2 - Ford Truck Enthusiasts Forums
Old 10-06-2003, 12:37 PM
dfawvor dfawvor is offline
dfawvor is starting off with a positive reputation.
Shutterman-
My check engine light never came on. I was quite honestly fed up with my truck and resigned to the fact that the motor would never have any power. Then I stopped trying to be cheap and bought a code reader. Best money ever spent. The key on/engine off told me the map sensor was bad so I replaced it. The key on/engine running test told me my O2 sensor was bad. I haven't changed that yet.
dfawvor
Old 10-06-2003, 04:16 PM
shutterman shutterman is offline
shutterman is starting off with a positive reputation.
dfawvor,
Thanks for the info.!! I will be buying a code reader very soon.
This is a very cool and helpful site !!!!!
shutterman
Old 03-09-2011, 07:04 PM
PeterSr PeterSr is offline
PeterSr is starting off with a positive reputation.
And I to love my 1992 Ford F250 5.8L that's rated at OVER 8600 lbs. I too have been having this problem which I believe I have narrowed down to the TPS. My question is: Will I have to reset the TPS if I remove it and replace it with a new one. Also, can this problem be caused by a bad MAP Sensor? I am at wits end! I have probably put several thousand dollars into the engine because of a nasty short in the electrical system that knocked out all my fusible links, my alternator, my starter and so on so forth. However, the EEC-IV and other electronics were not affected. This puzzles me!!?? I would appreciate your reply very much. Thanks.
Old 07-06-2015, 04:36 PM
Azframer Azframer is offline
Azframer is starting off with a positive reputation.
Sometimes a Mass Air Flow sensor will cause same symptoms. I had a issue like this with my 94' Ranger and I asked my mechanic friend about it. He told me to disconnect it and if that was my problem my engine would run better.
It would from time to time act like it was running out of gas, lacked power engine light would come on. I would take it out of gear and rev it a couple times engine light would go out and I was good for a while.
After unplugging it it ran great, so that was my problem then. I asked how much they were he said lets look at it 1st, we took it out and there was a small speck of dust on it, we blew it off with electronics air in a can. I was all set no money spent on new sensor. So check that if you are lacking power and your engine light comes on with lack of power.
Old 07-07-2015, 01:28 AM
Ed Bamba Ed Bamba is offline
Ed Bamba is starting off with a positive reputation.
The original post is almost twelve years old, and the post before yours is was posted over four years ago. Hopefully they got the issue resolved by now lol.
BTW, welcome to the forum, lots of knowledgeable folks on here. Hopefully you'll stick around and add to the knowledge base.
Old 07-07-2015, 06:54 PM
Yea I was looking for symptoms for TPS when I ran across this thread and thought I would put my problem on the record after I saw one with a engine light coming on.
Rick
Old 08-17-2015, 11:54 PM
ABeautifulTree ABeautifulTree is offline
ABeautifulTree is starting off with a positive reputation.
Do you know if the tps could be bad in these trucks and not throw the check engine light or a code the reader will get?
Old 08-18-2015, 10:22 AM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Yes....
Measure the output: Throttle Position Sensor
Be careful using an auto-ranging DVM, the display has some lag and it may change ranges on you during the testing. I manually set the voltage range then slowly open throttle while watching the meter (Key On Engine Off). It may take a few tries to determine if there are any dips or spikes in the output signal. It should sweep linearly from closed to open throttle.
Old 08-18-2015, 01:45 PM
JLuskin JLuskin is offline
JLuskin is starting off with a positive reputation.
I had a bad tps in my 95 351w. Bought the truck in April 2015 and noticed it didn't have much power and was kind of disappointed in my purchase. As the weather started to get hotter the truck ran worse. During days of say 80 degrees or hotter the truck would barely accelerate, probably took a good 3 or 4 minutes to get to 60 mph with the pedal to the floor. Had my mechanic look at it. He read the codes and came up with tps low circuit I believe. He replaced it and it felt like a brand new motor.
Old 08-18-2015, 05:34 PM
Craig5_12 Craig5_12 is offline
Craig5_12 is starting off with a positive reputation.
Just to throw my .02 into this very old thread...my 2003 jeep was downshifting constantly if I didn't hold the gas pedal completely still when I was cruising. The slightest bump in the road would make my foot move and the jeep would downshift. Turned out to be the TPS.
Old 08-18-2015, 05:48 PM
rla2005's Avatar
Both examples above are why you properly diagnose the issue. Start with the code check, if that passes break out the meter. For the sake of your wallet thickness please do not start throwing parts at the issue. The cheaper aftermarket TPS sensors are well known to be inferior to a Motorcraft brand. It's too much money to throw away for no reason.
Adaptive Cruise Error - "Blocked" twack 2017 Super Duty 9 01-08-2017 08:35 AM
Idle problems brian.b 1987 - 1996 F150 & Larger F-Series Trucks 6 01-06-2017 10:37 AM
Need Help: 2006 F250 Powerstroke. sstellmon 6.0L Power Stroke Diesel 2 03-12-2015 12:25 AM
99 f250 superduty engine cutting out when raining patho44 1999 to 2016 Super Duty 1 10-27-2012 01:48 AM
Sometimes it just dies? jesterdog Ford Inline Six, 200, 250, 4.9L / 300 5 07-12-2008 05:36 PM
Tags
1992, 58, 58l, 93, accelerator, bad, f150, f250, ford, map, position, sensor, symptoms, throttle, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
