DC to AC Power Inverter installed...
Hi,
Power Inverters rock
2000 Watt
Word of warning...having a big power inverter is great, but don't try plugging a full size vaccuum into it to clean up the truck for a show. The inverter can handle it, but the fuse between the inverter and battery don't like it very much.
Don't mind me; I'm just bored.
1LT Anthony Somma
2000 Watt
1LT Anthony Somma
Reserve time on your battery is how long it will last pulling 20 amps constantly. 20 amps x12 volts = 240 Watts So you can run 240 watts off your car battery for however long your batteries rated reserve time is. I spent a lot of time before football season this year researching this stuff. I considered a dual battery set up with an isolator coming off the alternator, but the expense of all the stuff I wanted to make that setup was getting close to the 1000 Watt Troy Bilt generator at Lowes. I am getting by with a 300 Watt inverter fine for now.
Nice install. I recently put a 750W mounted vertically inside my console, then fitted an excrursion rear console piece (the one with the cupholders built in and the opening for audio controls). I fabbed up a plug to go in the audio control opening. Pretty clean install, and since the inverter is mounted vertically, I really don't lose any space inside my center console...
