the beast strikes again
its been a bad week for my F250
on my way to work to drop off some paperwork, my heater core started to steam into the defrost vents. . . no big deal says i, i'll just get a new one in the morning.
WRONG
half way back home, the steam turns into a stream of hot coolant on the passenger side floor!
so anyhow, me and carquest strike a deal for the core. . .
after installing, now i cannot get much heat.
brand new core, new (2000 miles) thermostat, new (5000 miles) radiator. . .
any thoughts on where my heat went to?
yes, i did top the coolant off after dumping some on the ground.
T
WRONG
T
The heater core is in the cooling system and water circulates through it. If you put water in the radiator, it will fill the heater core, and push that air out. Water will have an easier time displacing the air if the cap is off and the system is not under pressure, even though it may not be able to get it out when the system is pressurized. Let the water pump do the work, just keep it topped off.
ok, first off, i got the heat werkin great,,,matter of fact i might be able to roast corn on the dash now
bleed the system trying all manners of methods, and finally when i could not get any hot air from the vents, i tried to get cold air...air temp from the vents didnt change...so i thought, hey, might be the heater control linkage?
so off the glovebox came, and there it was, i forgot to clip the end of the cable sleeve back into it holder on top of the core enclosure. after checking to see i had full motion on the dash slider, heat was restored.
thanks for all the replies!!
T.
T.
