removal of stripped bolts in manual hubs
hey guys. here's my problem. i'm trying to change the u joints in my front axle. 4 bolts are stripped out from the PO. i've tried the correct size allen key, pounding a screwdriver bit in, easy outs (snapped off). i've been using penetrating oil (swear i heard it laugh at me). i'm not worried about hub body damage as i'll be installing warn units next summer. i need to change the joints before winter tho. and before it gets any colder. thanks . i've got this over on the off road page as well.
manual hubs
i just had the same ordeal. i took the truck to shop they told me to do joints was 44$ part 550$ labor. i just laughed. took truck home did it myself. be aware that the spindles will probally be rusted yo mught want to soak them overnight before removing. i had all but one allen bolt strip. had to drill 9 out. be carefull and do it slow. you can get replacement bolt kit for 5.00 for set of 5. hope this helps!
Nothing Special
05-17-2014 09:35 AM
ErrorS
1978 - 1996 Big Bronco
09-28-2010 06:39 PM
dale88
02-16-2010 12:29 PM
