Keyless entry code for 2003 Explorer
Old 09-24-2003, 07:59 PM
danzadra's Avatar
danzadra
danzadra is offline
I bought a used 2003 Explorer XLT and don't know the code for the keyless entry. I understand it's on some module, but where is the module?
Old 09-24-2003, 09:16 PM
99ExplorerXLT's Avatar
99ExplorerXLT
99ExplorerXLT is offline
Not sure on the 2003, but on the 99 its located in the back behind the panel that hides the jack on the driveds side.
You have to get a flashlight and look really carefully back in there to find it. Once I saw the module with the code on it I really had to strain to read the code. On the 99 the code is 5 digits.
Hope this helps.
Carlen
Old 09-26-2003, 06:41 AM
danzadra's Avatar
danzadra
danzadra is offline
Still looking. Anyone know where it is on a 2003 Ford Explorer
Old 09-26-2003, 08:21 AM
andylant2003's Avatar
andylant2003
andylant2003 is offline
If you can't find it the dealer was supposed to give you a card with the code on it. I suggest you go back to the dealer or call them and have the stock number the dealer had on the truck available. I bought my truck about a moth ago and the dealer handed me a little plastic card that had the manufacturer's code on it.
Old 09-26-2003, 03:56 PM
yankee15's Avatar
yankee15
yankee15 is offline
Talking Door Key Code
I just got through this ordeal with my 2002 Explorer. Bye the way thanks everyone for there great ideas. But, it is located on the passengers side on mine. I had that whole truck torn apart on the drivers side and could not find it. Then a guy at work said it's buy the rear wiper fill. Which is on passenger side (on mine). Sure enough five minutes later I could open my door with the key pad!! It is a grey box about 6 inches long by maybe 4 inches wide. It has a 5 digit number stamped on a white label. That's it. It's just behind the door jam of the back passenger door. Just pop the back corner molding off, the molding where the back seat belt is, the molding back by the bumper(runs from side to side of the truck), then pop big pass. back panel loose(don't have to take it out) look in from the top just behind the back seat and you'll see it. Good luck.
Old 09-27-2003, 04:51 PM
danzadra's Avatar
danzadra
danzadra is offline
Still no luck. Anyone with knowledge on finding it on a 2003 Explorer? Looking for the keyless entry code.
jasnjen
26
02-27-2018 11:53 AM
FordTruckfan89
08-28-2016 03:52 PM
F350 king ranch
1999 to 2016 Super Duty
09-01-2013 04:06 PM
manny83107
04-07-2012 06:49 PM
bdalexan
08-30-2003 12:25 AM
Quick Reply: Keyless entry code for 2003 Explorer
