Keyless entry code for 2003 Explorer - Ford Truck Enthusiasts Forums
Old 09-24-2003, 08:59 PM
danzadra danzadra is offline
danzadra is starting off with a positive reputation.
I bought a used 2003 Explorer XLT and don't know the code for the keyless entry. I understand it's on some module, but where is the module?
Old 09-24-2003, 10:16 PM
99ExplorerXLT 99ExplorerXLT is offline
99ExplorerXLT is starting off with a positive reputation.
Not sure on the 2003, but on the 99 its located in the back behind the panel that hides the jack on the driveds side.
You have to get a flashlight and look really carefully back in there to find it. Once I saw the module with the code on it I really had to strain to read the code. On the 99 the code is 5 digits.
Hope this helps.
Carlen
Old 09-26-2003, 07:41 AM
Still looking. Anyone know where it is on a 2003 Ford Explorer
Old 09-26-2003, 09:21 AM
andylant2003 andylant2003 is offline
andylant2003 is starting off with a positive reputation.
If you can't find it the dealer was supposed to give you a card with the code on it. I suggest you go back to the dealer or call them and have the stock number the dealer had on the truck available. I bought my truck about a moth ago and the dealer handed me a little plastic card that had the manufacturer's code on it.
Old 09-26-2003, 04:56 PM
yankee15 yankee15 is offline
yankee15 is starting off with a positive reputation.
Talking Door Key Code
I just got through this ordeal with my 2002 Explorer. Bye the way thanks everyone for there great ideas. But, it is located on the passengers side on mine. I had that whole truck torn apart on the drivers side and could not find it. Then a guy at work said it's buy the rear wiper fill. Which is on passenger side (on mine). Sure enough five minutes later I could open my door with the key pad!! It is a grey box about 6 inches long by maybe 4 inches wide. It has a 5 digit number stamped on a white label. That's it. It's just behind the door jam of the back passenger door. Just pop the back corner molding off, the molding where the back seat belt is, the molding back by the bumper(runs from side to side of the truck), then pop big pass. back panel loose(don't have to take it out) look in from the top just behind the back seat and you'll see it. Good luck.
Old 09-27-2003, 05:51 PM
Still no luck. Anyone with knowledge on finding it on a 2003 Explorer? Looking for the keyless entry code.
99 explorer Keyless entry module question FordTruckfan89 Explorer, Sport Trac, Mountaineer & Aviator 5 08-28-2016 04:52 PM
Keyless Entry manny83107 1999 to 2016 Super Duty 5 04-07-2012 07:49 PM
2003 Excursion Keyless Entry... Shriner Excursion - King of SUVs 7 07-23-2006 07:58 AM
2002 Explorer Keyless Entry Combo Location jasnjen Explorer, Sport Trac, Mountaineer & Aviator 25 06-08-2004 09:29 PM
How do I reprogram factory keyless entry code? jbookrun Explorer, Sport Trac, Mountaineer & Aviator 9 12-08-2003 05:55 PM
Tags
2003, code, default, entry, explorer, find, ford, keyless, locatedin, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
