1988 Bronco II water leaks in the cab - Ford Truck Enthusiasts Forums
Bronco II Ford Bronco II
Old 09-24-2003, 08:19 PM
lgamech lgamech is offline
lgamech is starting off with a positive reputation.
Question 1988 Bronco II water leaks in the cab
I have been knocking my brains out trying to find out where this leak is. To this date I've narrowed the leaks to the area just under the driver side pedals. A little history on this B II. I bought this as a winter and fishing truck. the previous owner really abused this pup and I've been slowly restoring to better than new shape. But my main roadblock is the leaks. Any help on this matter will be greatly appreciated.
Mike.
1988 Bronco II XLT, 2.9 L V6 4wd.
Old 09-25-2003, 03:00 AM
lewie lewie is offline
lewie is starting off with a positive reputation.
Are you talking about water or radiator fluid? Is the moisture only on the drivers side?
lewie
Old 09-26-2003, 11:54 AM
Hiya.
actually its just plain water. it seeps in when it rains, and most of the concentration is under the drivers feet. The passenger side also gets damp but no where near the amount the driver has. I have search high and low, pulled out 2 wet insulation bags from the engine firewall side. I'm up to using a hose to find the leak, but have to wait till the weather gets better.
Mike
1988 Bronco II XLT, 2.9 L V6. 4X4
Old 09-26-2003, 12:31 PM
goinlowbII goinlowbII is offline
goinlowbII is starting off with a positive reputation.
my friend had a problem like this and he had a gromit that had broke around the firewall , i was looking on my 88 and mine around the brake pedel was a lil wet too .. other than that did you check the bottom windsheild seal ? it could be rolling down the back of the dash and on the inner wall . good luck
Old 09-28-2003, 03:14 PM
well I found the source of the leak. Theres a cavity on both sides of the firewall that allows the water from the wiper linkage area and the hood seams to leak out. Water is colleting in a little " Catch" pocket below and to the left of this area. Water has accumulating and rotted a small hole in the area just under the emergency brake along the side of the wall. on both the left and right side of the driver/pass foot area.
I'm debating wether to fill the area with foam insulation or find the low spot and drill a drain hole and grommet .
Mike
1988 Bronco II XLT, 2.9L V6, 4WD.
Old 10-15-2013, 10:56 PM
James Mahan James Mahan is offline
James Mahan is starting off with a positive reputation.
leaks
I have the same problem what did you end up doing
Old 10-15-2013, 11:03 PM
canoechris's Avatar
canoechris canoechris is offline
canoechris is starting off with a positive reputation.
same here. seems to be collecting in the vents with the wiper linkage..haven't found found how or where it drains
Bronco II Wheel Adapters tsytsa Bronco II 5 01-06-2016 12:50 PM
Transmission swap mwood553 Bronco II 2 03-10-2015 05:43 PM
Bronco II leaks flopp Bronco II 22 02-13-2014 11:19 AM
A question about a fuel pump issue... Andy1416 Bronco II 2 07-11-2013 02:32 AM
1988 Bronco II eddyjr Bronco II 4 02-19-2013 07:01 PM
Tags
1988, bronco, ford, ii, leaks, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
