Starter woes
Starter woes
My 1994 4X4 Supercab left me in the lurch the other day. I parked at the mall, went in, and when I got back and tried to start the truck all I got was a loud click.
I knew the battery was OK, and checked all connections.While under the truck, I whacked the starter and starter drive with a tire iron out of frustration. LO AND BEHOLD, this did the trick and the truck started and has started well for a week.
But, now I feel I can't trust it. When will it let me down again? And, what if a whack doesn't fix the problem? Anyone know what could be wrong?
Starter woes
I'm guessing your starter bendix was stuck, and your hit jarred it loose. I've done the same on a number of occasions with a number of different trucks, but I took heed that the starter had a problem and replaced it in just about every case. Not to say that you'll ever have a problem again, but I would watch it. If the bendix is sticking, something is worn or out of tolerance, and you'll likely see a problem some time again. If it acts up again, you may consider replacing it.
Starter woes
On my '95 I have had the same problem. There's about an 8 gauge wire with a female spade connector that I figure energizes the solenoid, it has gotten dust and debris under it and really needs to be pinched with a needle nose to tighten it up.Every single time a wiggle on it fixes mine. Basically a short cut,
****-poor design for the application.
