2.8 pistons - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
2.8 pistons
Old 09-24-2003, 11:48 AM
fordguy49 fordguy49 is offline
fordguy49 is starting off with a positive reputation.
2.8 pistons
Does any know if there are higher compression pistons for the 2.8? Im having my heads milled but I dont think that will be enough to achieve the 10:1 ratio I want.
Old 09-24-2003, 01:31 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
2.8 pistons
Welcome to FTE!!!
Sorry can't help with the piston. If you don't get an answer here you could also try posting this on our 2.8 engine or Bronco II forums.
Old 09-24-2003, 02:05 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
2.8 pistons
Contact some of the piston manufacturers. I can't remember any names at the moment.
2.8 cologne pistons Taunus 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 4 02-10-2009 02:05 AM
stroke a 2.8?, can it be done? cowboy4christ38 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 7 02-09-2009 07:28 AM
2.8 flat tops in a 2.9 admiralturbo 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 0 04-19-2005 01:21 AM
2.8 Performance Mods ?? Katmandu 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 4 11-16-2004 05:32 PM
Supercharged 2.8L S/C2.8 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 08-09-2004 06:07 PM
Tags
28, areostar, bronco, capri, dome, find, ford, ii, pistions, piston, pistons, ranger, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
