Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 09-24-2003, 10:26 AM
Oscar Meier Oscar Meier is offline
Garage is empty, add now
Oscar Meier is starting off with a positive reputation.
79 4x4 351M oil pan removal
The oil pump on my '79 4x4 351M gave out last night. The oil pressure has been going down for the last couple of weeks. I checked the gauge operation and it works fine; but, does not register any oil pressure when engine is running.
My question, can you remove the oil pan without pulling the engine? If I unbolt the pan, will it clear the crossmember? I am sure I will have to remove the exhaust manifold pipe because left side maniflod pipe crosses under the oil pan.
Thanks for the help
__________________
'79 150 4x4; '86 150 4x2; & '96 150 4x2 all with 300's and '85 SB 4x4 w/ 302 FI.
  #2 (permalink)
Old 09-24-2003, 10:48 AM
grapegravy's Avatar
grapegravy grapegravy is offline
grapegravy is starting off with a positive reputation.
It'll drop down enough to get a hand in there and check to see if the pump is still on the tube. Depending on your firewall clearance, also a way is to let the motor mounts loose and jack the engine/transmission up as far as it will go. That'll give you at least a few more inches to check it. But, as far as I know,, the oilpan wil not come out without serious dismantling of the drivetrain. Did you check for current from the sender unit? Put it on a meter with the truck running. You might want to go to a junkyard and pick up a different gauge and see if it registers on that one before going to all the hassle of getting into the bottomend. Also, pull the sender and clean it up, check it out. They are dirt cheap too, try replacing that. If the engine isn't making any noise like it's starved for oil, then it's more than likely just in the system, not in the pan. Always check the easy stuff first
__________________
1977 F-350 Supercab
Dan
  #3 (permalink)
Old 09-24-2003, 11:27 AM
I removed the sending unit and rigged up and adapor and put 50# air pressure to it and the gauge came right up. I also cranked the engine for about 15 seconds and almost no oil came out the sending unit opening.
__________________
  #4 (permalink)
Old 09-24-2003, 12:13 PM
grapegravy's Avatar
Time to drop the pan then, you've either got a clogged/shot/disengaged pickup or problems farther up the tube. Take the screen out and see what you find.
__________________
1977 F-350 Supercab
Dan
  #5 (permalink)
Old 09-24-2003, 12:33 PM
I am not looking forward to this job - I wonder if I wouldn't be better off just pulling the engine. I did a search on oil pan removal and there are several "horror" stories on oil pumps & pan removal.
Thanks for the info.
__________________
  #6 (permalink)
Old 09-24-2003, 04:35 PM
grapegravy's Avatar
If you are willing to take the time and have the equipment necessary, it's always better to pull the engine with something like this. Give everything else a good once over while it's out. Save ya headaches in the future. Most importantly, lol, if it looks questionable,,,, Replace It!!!
__________________
1977 F-350 Supercab
Dan
  #7 (permalink)
Old 09-24-2003, 08:39 PM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
On a 79 4wd the oil pan should be easy to get off. The crossmember is under the pulley area of engine. If you need more room between engine and axle you can jack up the frame. The horror stories you read are from 2wd trucks and 80-later which have a large crossmember directly under the engine.
  #8 (permalink)
Old 09-24-2003, 10:21 PM
I got back under the front end and the crossmember is more to the front of the engine. The truck is a factory "high-boy" and there is plenty of room between the axle and bottom of pan. I will have to remove the exhaust manifold pipe; but, that's a lot easier than pulling the engine.
Thanks for the follow-up information - I was starting a parts for sale sign when I checked back for messages.
__________________
  #9 (permalink)
Old 09-25-2003, 02:40 PM
460429_freak's Avatar
460429_freak 460429_freak is offline
460429_freak is starting off with a positive reputation.
on mine here is what I did I jacked my truck up where the wheels was off the ground blocked it up with railraod ties not pieces whole one from on side to the other where the wheel would dangle (to get more clearence) un did the exhauste motor mounts
used a floor jack with a peice of wood on the harminc balacer to lift my motor and slid the pan out... that was then now I have a shop with a cherry picker this was a driveway fix when I was young and dumb
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #10 (permalink)
Old 09-25-2003, 10:01 PM
I would not call myself dumb - you sucessfully completed a fairly difficult repair job with the resources you had available to you.
__________________
Tags
1977, 1978, 1979, 351m, 4x4, change, f100, f150, ford, gasket, leak, oil, pan, removal, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
