9.5:1 Extreme Energy 4x4
I recently did a rebuild on my 460 including a light port job along with port matching the intake. I also put a Comp Cams camshaft and forged speed pro pistons. My question is about my cams specs they are .514in 514ex 256in 262ex and 210in 218ex @.050 with 111deg of LS. The summit catalog said the cam is good for 1000-5000. The pistons are domed and are standard bore. I should have about 9.5:1. Anyone had experience with a similar setup? I know that I need to have a chip burned for this setup to run best because I am running speed density. But I am wondering if this cam is compatible with the compression I now have. I went to get the truck dyno'd last week and It only gave 230hp and 330lbft the timing was at 6deg and fuel presssure at 42lbs. My A/F was about 13 at 2500 and from there it went to 14+ until they cut it at 4500.
Thanks
Justin
Thanks
Justin
I am running the largest Exteme 4x4 cam in my 9.5-1 466. I haven't noticed any problems with breathability. But then again my engine is setup slightly differently then yours. I have a carb vise EFI and mine is set up to 1970 standards with the exception of CJ size valves.
I am also trying to find a colder plug I am currently running an autolite 25. I am having problems finding out which plugs are colder. And I always run 91 octane. The truck has a real hard time on hot sunny days. I cant wait to get my chip burned I definitly feal that it will make a substantial difference. Justin
