lightning spring question - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 09-19-2003, 04:38 PM
nicechad2 nicechad2 is offline
nicechad2 is starting off with a positive reputation.
I was just at the local pull-a-part yard, and they have a 1997 Lightning extended cab out there. I have a 1997 f150 XLT, reg cab, SWB, V6. My wheels got to turning and I looked, the front springs, shocks, and control arms and spindles are all there in the front, and the rear end still has the leafs. My question is this, If I go pull the front end and rear suspension parts and swap them onto my truck, will I gain any lowering, since I have a V6, will the lighter engine just make the springs about the same in the front. Plus the weight of the extended cab. I may just swap all this stuff and not gain anything. Also, what makes the lightning lower, is it the leaf springs and coil springs, or leafs and spindles, or are the control arms different, or all or some of the above. Is it worth it? What kind of gains, (or suspension losses in height) will I see? Anyone done this? Thanks, Chad
Old 09-19-2003, 08:02 PM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
No they don't. Lightnings are not available with extended cab and were not available in 97. The only years for Lightnings are 93-95 and 99-later. There was a company that converted 93-95 Lightnings to extended cab. I don't know of any 99-later that were converted.
Old 09-19-2003, 08:38 PM
that's what I thought, so maybe it is just a rebadged xlt or lariat...
had fender badges and leather, but no ground effects, hit in front, but found some parts of the front airdam in the bed
Old 09-19-2003, 08:40 PM
anyway, back to the question, what lowers the lightning, springs or spindles or what?
Tags
ford, lightning, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
