What top radiator hose to use?
Have you tried NAPA? That's where I got my hoses and my upper is sized the way you're looking for.
Intrestingly enough, NAPA lists the 460 as an option in an F-150 in their computers. I'm guessing because of the popularity of this swap. I just had them look up a hose for a 77' F-150 w/460 and I got the hose I'll bet your looking for.
That's a new one on me. Was it some sort of special edition sort of like the 454SS?
Speaking of thread hi-jacking, I forgot to answer the original question. If you are using a 45 degree housing then an upper hose from a 400 would work too. For the lower hose, the best fit I've found, when using the 400 radiator, is a 460 hose cut down to length. Good luck.
tweak1029
1997 - 2003 F150
03-25-2015 11:33 PM
