Replacement Bolt Size (300 I-6 and NP435) - Ford Truck Enthusiasts Forums
Old 09-19-2003, 11:50 AM
tmh tmh is offline
tmh is starting off with a positive reputation.
Can anyone tell me what size bolts connect the bell housing of the I-6 to the transmission. In my case the
tranny is an NP435 (4 speed manual, granny low). Several of the bolts appear missing and I don't want to remove the one that I can find to measure it.
Thanks
Old 09-20-2003, 02:05 AM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I have the same set up, I trying to remember it has been a while since I took em out. I think they were a 1/2 inch diameter shank about 2 or 2.5 inches long. Standard thread, hope this helps; oh don't be afraid to remove the bolts. The bellhousing has guidepins and the weight of the motor is pretty balanced so it isn't going anywhere. If it bothers you, you could support the front of the tranny with a floor jack when you take the bolts out.
Old 09-20-2003, 02:22 AM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
The top two are 1 1/2", other four are 2", all are 7/16 course thread.
Old 09-20-2003, 02:55 AM
Pkupman82's Avatar
There you go, I couldn't remember right off, It's not very often that I have to work on my truck.
Old 09-22-2003, 08:29 AM
tmh tmh is offline
Thank you I appreciate the help
NP435 to 300 I6 Bell Housing Samsn4 WTB - Parts & other 0 11-07-2013 03:32 AM
390 fe bellhousing Q dirty_red_lobster FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 12-30-2010 07:39 PM
What clutch and flywheel assembly 460powerhouse Clutch, Transmission, Differential, Axle & Transfer Case 20 03-03-2006 09:16 PM
300 NP435 and 360 NP435 compatible dino360 Clutch, Transmission, Differential, Axle & Transfer Case 0 10-27-2004 12:09 AM
NP435 2wd? Can a transfer case mount to it? aunchman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-05-2002 05:55 PM
Tags
1984, 300, bolt, ford, replacement, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
