Aerostar Ford Aerostar
Ford Radio Schematic Question
Old 09-18-2003, 08:40 PM
sail2244's Avatar
sail2244
sail2244 is offline
I have puzzle on my hands. I purchased a ford radio out of a 1995 aerostar and i am trying to install it in a 1984 F150, I have all the F150 schematics. But no aerostar schematics. The radio is a standard ford Radio F68F 19B132 CA . I visited a local wrecking yard and found the correct connector plugs for the back of the radio and now i really have lots of questions. I visited the Install Doctor website and got some information but none of my wire colors match. I am a bit nervous about hooking up the radio without some verification of the aerostar schematics or the radio schematics. There are two large plugs (8 pin) and one small plug 2 pin. I have no clue as to what the two pin plug does.
When looking at the back of the radio one 8 pin connector is on the right another is on the left they have opposing keyed connector plugs the small 2 pin connector is in between the two large connectors. Which pins are the power?
Can anyone help?
Old 12-06-2005, 02:27 AM
w8mia's Avatar
w8mia
w8mia is offline
Wink Ford Aerostar Radio Wiring?
Hello I a new user and noticed this old post of yours. I now have the same problem not knowing the wiring of the two large (7 & 8 pin) connectors on the rear of the F68F series radio I am trying to install in another truck. I have figured out the 8 pin Right Hand plug are the 4 speaker outputs (2 left & 2 right, front & rear). I am guessing the small 2 pin plug is for an auto retract antenna but that is only a guress and not important to me. I would like to know what it is however.
I have also figured out that the top pin on the left 7-pin connector should be + 12v and the 6 th pin down from the top is chassis ground. Now I am stuck!!! I understand I must have both the +12v Ignition and the +12v Key both powered up to get the radio to work but not sure of the pin to use, don't want to burn the radio up.
I know there 4 additional pins to try applying +12v to which are Pins-2, 3, 4 & 7 at the bottom. Did you ever solve this old problem. Do you have the wiring diagram of the 2 large and 1 small connectors? If so will you please get in touch with me. ahoecker@citlink.net. Thank you very much, August
Old 12-06-2005, 06:47 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...WOW old thread, no matter...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old 12-06-2005, 06:12 PM
bobcf's Avatar
bobcf
bobcf is offline
not sure if this will help, the areostars have radio controls in the back seat. that might be the extra wires. also look at www.installdr.com under "quick raido wireing info"
Old 12-06-2005, 09:35 PM
cookkd's Avatar
cookkd
cookkd is offline
The two 8 pin connectors are C257 and C258. the Pinouts are as follows:
C257:
1 (LG/Y) Radio Memory Power
2 Not used
3 (Y/BK) Radio Power
4 (LB/R) Radio Graphics Lighting
5 (O/BK) Display Back Lighting (LCD)
6 (R) Radio Ground
7 (O/LB) Radio "ON" Signal (Elect. Cluster)
8 Not Used
C258
1 (O/LG) Left Front Speaker (Standard Cluster)
2 (BK/W) Common
3 (PK/LG) Left Rear Channel
4 (R/BK) Seek Station Up
5 (W/LG) Right Front Speaker (Standard Cluster)
6 (O/BK) Seek Stations Down
7 (PK/LB) Right Rear Channel
8 (BG/O) Seek for Memory Station
I don't see anything resembling a 2 pin connector.
Hope this helps.
Old 12-06-2005, 09:50 PM
pfogle's Avatar
pfogle
pfogle is offline
The 2 pin connector is an older style (pre '86). The big lug is the accessory feed, and the little lug is the illumination. The 8 pin plug is the speaker connector. There should be a big metal ring that the radio slips into in the dash, this is the ground, there is no radio ground wire in the harness. Only speaker grounds, and that metal piece in the dash.
Old 12-06-2005, 11:03 PM
93nighthawk's Avatar
93nighthawk
93nighthawk is offline
Welcome!
I guess no thread is truely dead, even one that took over two years to get a reply.
Old 12-07-2005, 11:42 AM
Pablo-UA's Avatar
Pablo-UA
Pablo-UA is offline
I have wiring diagrams, but not scanned and in russian... I will translate it tomorrow and post as image...
RichHawley
2004 - 2008 F150
05-29-2017 11:07 PM
Dieseldemon815
6.7L Power Stroke Diesel
07-08-2016 05:36 PM
mrnapolean1
03-19-2016 09:50 PM
enriquemo2
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-08-2015 07:02 PM
AlbanyHDTV
1997-2006 Expedition & Navigator
11-08-2011 03:22 PM
Quick Reply: Ford Radio Schematic Question
