94 F150 Rotors
94 F150 Rotors
The best thing would be to get a manual that way you have all the torque specs. and such. Anyway here goes:
1 jack up and remove tire
2 remove brake caliper
3 remove locking hub(IF 4X4)
4 using magnet remove small pin
5 unbolt nut(you will need a special socket to avoid damage)
6 pull hub off(since you got it off replace bearings)
7 pack new bearings with grease
8 you will need new wheel seals
9 remove seals install rear bearing and put new seal in place
10 reverse disassembly process
sorry if I missed a step I don't think I did but it has been a while since I did mine. The new bearings and seals can be installed on the new rotor on the truck just put on the rear for now.
cpnhgnjnky
95 F150 Eddie Bauer
4X4 5.8L
alot of stuff
cpnhgnjnky
95 F150 Eddie Bauer
4X4 5.8L
alot of stuff
