ac wol relay
Old 09-18-2003, 03:02 PM
santafean's Avatar
santafean
santafean is offline
ac wol relay
94 ford ranger 4x4 blower suddenly quit working after the ac was worked on. can't take it back to the place it was worked on.
got into the fuse panel in engine compartment and there was a home made looking jumper in the a/c wol relay position. we replaced that relay, reassembled the blower, turned on the engine and we had a blower...for about 10 secs. then it went dead again. no clicks, no sound when blower switch is turned, no air coming out of the vents.
any ideas on what would be causing this? or anything else we could check before we take it back to a shop? all fuses in the underdash fuse panel are fine, and replaced them just for good measure. ( a 10 amp and a 30 amp)
blower fan worked before the ac was worked on, so i'm assuming they mechanic did something odd, or did not know what he was doing.
Old 09-22-2003, 06:29 AM
HomerWinzlow's Avatar
HomerWinzlow
HomerWinzlow is offline
ac wol relay
Could be coincidence, since most AC repairs dont have anything to do with the blower. Intermittent fails like that could be a bad motor, resistor, switch or relay. Perhaps when you wiggled the wiring about that allowed the motor to work awhile then faulted again.
Jefftopgun
07-13-2017 04:58 PM
mrturtell
1999 to 2016 Super Duty
10-02-2016 07:24 AM
jtcdudeman
09-16-2016 01:05 PM
mwilliamshs
03-18-2015 12:22 PM
ROBBINthaHOOD
08-20-2012 07:17 PM
Quick Reply: ac wol relay
