94 F-150
94 F-150
Need help.
My reverse lights, running lights and hazard lights do not work. I have checked the power distribution box and fuse box and there are no burnt fuses.
Anyone ever have this problem or have any idea what could be wrong or how I could try and fix it?
thanks in advance
Chance
thanks in advance
Chance
94 F-150
No I can't help and I apologize I'm not much on electrical stuff. Anyways try a dealer they have the computer to get your problem codes. I know dealers are expensive, but may end up being cheaper than replacing all kinds of worthless stuff in the long run. I usually try to befriend the service manager this helps cut costs also. Good luck hope all works out.
cpnhgnjnky
95 Eddie Bauer F150 4X4
5.8L w/to much to type
cpnhgnjnky
94 F-150
Sounds like a bad ground. Is it just the tail lights that are not working? Do the front turn signals operate? I would check the rear wiring for broken leads. You may just want to add a grounding wire to the tail lights existing wire harness. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
