6.0 No Power - Ford Truck Enthusiasts Forums
6.0 No Power
Old 09-17-2003, 10:42 AM
Stroker67 Stroker67 is offline
Stroker67 is starting off with a positive reputation.
Angry 6.0 No Power
I own a 2003 F-350 with the 6.0 Powerstroke Diesel. I have owned it for about 5 months now and have racked up 12000 miles on it. It has given me problems since the day I drove it off the lot. When I fisrt bought the truck it had tons of power now the more I drive it the less it has. My first major problem started about 2 months ago I was trying to get on the highway when I lost all power I couldn't get the truck up to 60mph. I took it to Ford an they told me a few codes went off but i shouldn't worry about it, I probably got bad fuel. I was kinda pissed that they acted like nothing was worng with my truck. Then about 800 miles later it was doing it again I again had no power. I took it to them again and they ran it on the computer and a few codes came up(P0402, 2263, P0113). After these three codes came up they tryed to tell me that a vaccume hose was lose on my air box and it was my fault because I must have knocked it off when I changed my oil. I then proceded to tell them that they were the last to change my oil and I doubt that that one hose made these codes go off. They said well that was it and they fixed it for me. Well 1000 miles later I have no power again and for the third time took it in and they had codes(P0402 and P2263) The Boost and EGR codes. They replaced the EGR and just reset the boost code. Now its been about 200 miles on the new EGR and the truck still is lacking power and now it has a strong hesitation when I try increase speed. If anyone else is having problems like this let me know.
Old 09-17-2003, 10:54 AM
paschman2000 paschman2000 is offline
paschman2000 is starting off with a positive reputation.
6.0 No Power
Is it cold out when these problems happen? If the truck isn't warmed up fully the waiste-gate is still closed rfesulting in no power at all. Doubt thats the problem but you never know.
Old 09-17-2003, 02:25 PM
International Tech's Avatar
International Tech International Tech is offline
International Tech is starting off with a positive reputation.
6.0 No Power
sounds like the exhaust back pressure device is hanging closed.
Old 09-17-2003, 07:01 PM
glk glk is offline
glk is starting off with a positive reputation.
6.0 No Power
I had very similar problem, They replaced the turbo and replaced the PCM and down loaded the new codes for the computer after 8/18/03 and the power came back. The pcm has been a major problem with lack in the power with others.
Old 09-17-2003, 09:30 PM
rfm1 rfm1 is offline
rfm1 is starting off with a positive reputation.
6.0 No Power
Had very similar problems check my thread at 6.0 problems help.
Rich
Old 09-17-2003, 10:59 PM
Debug Debug is offline
Debug is starting off with a positive reputation.
6.0 No Power
You need to go to a different service center. The clowns at the dealer you have been visiting don't know what they are talking about.
Old 09-17-2003, 11:58 PM
resqdawg3's Avatar
resqdawg3 resqdawg3 is offline
resqdawg3 is starting off with a positive reputation.
6.0 No Power
Quote:
If the wastgate is closed, the truck would be producing gobs of boost! The wastegate is just that, when it opens, it dumps excess boost pressure. This way it keeps everything happy, and boost where it's supposed to be.
Maybe you're thinking of the little actuator for the VVT on the Turbo. If that isn't working right, you'd be producing very little, if any boost. Depending on what position it was stuck in.
Old 09-18-2003, 12:33 PM
mmfarm2517 mmfarm2517 is offline
mmfarm2517 is starting off with a positive reputation.
6.0 No Power
i have a 2003 f250 and have had problems with my truck from about 300 miles on it i have 14,000 one it know and jusy tild ford that i was don,twith it that i want a new truck and if that wasn,t in there plans i was going to get a lawyer and file undewr the lemon law. 9-18-03
Old 09-18-2003, 03:10 PM
6.0 No Power
Can you please type SLOWER! I can't understand anything you just typed.
resqdawg3 Just as you said, The wastegate is just that, when it opens, it dumps excess boost pressure. So, if it is still closed how is the boost getting to the engine? Maybe i'm just not understanding you.
Paschman
Old 09-18-2003, 03:53 PM
resqdawg3's Avatar
6.0 No Power
Quote:
The Wastegate
Most automotive turbochargers have a wastegate, which allows the use of a smaller turbocharger to reduce lag while preventing it from spinning too quickly at high engine speeds. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure. If the pressure gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
HowStuffWorks.com
Prolly the greatest site to learn stuff from.....
For an internal wastegate, it vent's the excess pressure into the exhaust stream on the exhaust side of the turbo. For an external wastegate, it just dumps the excess pressure to the atmosphere.
Old 09-19-2003, 09:27 AM
6.0 No Power
Thanks for all the info. I'm going to be taking it to a different dealership to see if they will help me. Thanks agian
Old 09-19-2003, 09:29 AM
6.0 No Power
P2263 & no boost at start up Hyperryd 6.0L Power Stroke Diesel 5 10-08-2013 10:00 PM
Turbo codes P2263/P2563 sd convert 6.4L Power Stroke Diesel 3 01-26-2012 07:55 AM
EGR failing? BRay09 6.0L Power Stroke Diesel 4 10-03-2011 10:52 AM
97 Explorer - P0402 Trouble Code - HELP ynot2244 Explorer, Sport Trac, Mountaineer & Aviator 2 09-28-2005 11:35 AM
P0401 and P0402 codes? kc5deb 1997 - 2003 F150 8 12-09-2004 09:50 PM
Tags
60, boost, diesel, ford, gate, p0113, p0402, power, restart
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
