I need you help here
Can I just remove the pulley on my smop pump and put a smaller belt on. Will this work?
I tried to remove my air pump tonight, and after removing all the hoses and bolts, it still won't come off. Does the altinator have to come off too? I'm doing this on small time frame, I need my truck to run kids back and forth from school. I put the pump back together tonight, but need to get this fixed soon.
Its a 1988 ford 302/EFI. Can I leave the pump on minus pulley. I'm not worried about emissions. Will I have to pinch off a hose or something due to vacuum. My pump is about to lock up , it sounds terrible.
I removed my pump and installed a smaller belt. I took the truck to the parts store and removed the pulley (3 13mm bolts) and test fit a few belts till I found one that fit. I got a general idea by taking a piece of string and wrapping it around the pullys. I marked it where the ends overlapped and told the parts guy the length in inches. I wish I could remember the length.
Did you look on the side of the engine behind the pump? I know there was the long bolt from the front, and then I think there was one on the back. There are only 2 bolts that I can remember holding it. It's been a couple months.
Your idea of removing the pulley will work though. I ran the shorter belt a couple weeks before I had the time to remove the whole pump.
88 F-150 4X4 XLT Lariat w/5.0 EFI 5 spd (DAILY DRIVER)
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4 (NEW TOY- DETAILS WHEN FINISHED)
85 Old Cutlass Supreme 350/TH350 Holley 4160,Edelbrock Performer intake, el-cheapo headers, General Kinetics 270H series cam, 15.588 best 1/4 mile with original 10 bolt 2.41 gears (OLD TOY)
I'm not really worried about that since we don't have emissions here. Plus when I bought the truck it was minus cats already.
