Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 09-16-2003, 02:49 PM
casinoden casinoden is offline
Garage is empty, add now
casinoden is starting off with a positive reputation.
2002 e250 van fuse diagram
Hello. I got robbed and they stole my owners manual! I have a 2002 e250 van, could someone either post a fuse block diagram or tell me which one of these fuses is for the radio?
Thanks!
  #2 (permalink)
Old 09-16-2003, 08:20 PM
John Ecker John Ecker is offline
John Ecker is starting off with a positive reputation.
Hi, I checked the owners guide for my 97 E250, hope it is the same as a 2002. It says in the instrument panel fuse panel.. Fuse #3 --15 Amp--is for : Headlamp switch, radio sense, rear radio control, Remote keyless entry module.
#4 --15 Amp--is for :Power mirrors, modified vhicle, power locks w/RKE, Headlamp switch (dome), illuminated entry, Courtesy lamp switches, Radio (KAP), Cluster (KAP) , warning chime
No other fuses mention anything about the radio in either the instrument panel or motor compartment fuse panels. Hope this helps. Good Luck, John
  #3 (permalink)
Old 09-17-2003, 09:08 AM
that fuse 3 sure was the culprit
thanks for your help, i look forward to passing on the favor
Tags
1978, 2002, 2003, 250, box, courtesy, diagram, e250, ford, fuse, fuses, lamps, solenoid, van, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
