Removing the coffee can? - Ford Truck Enthusiasts Forums
Old 09-16-2003, 01:57 PM
HrlyDr's Avatar
HrlyDr HrlyDr is offline
HrlyDr is starting off with a positive reputation.
Question Removing the coffee can?
What does it do? Why disconnect it?
I traced the vacuum hoses from my "coffee can" last night. One runs into a muliple port connection on the right side of the truck, and the other runs into what looks like an overgrown EGR valve on the left side of the truck, above the fuel/water separator.
Can somebody explain the advantages to me?
I have a Banks Sidewinder on my 6.9...will removing the coffee can have an adverse effect with this set up?
I never heard of this mod before, but I've been seeing it metioned here in a few threads. Any info is much appreciated!
Old 09-17-2003, 10:54 AM
HrlyDr's Avatar
BTT
anybody?
Old 09-18-2003, 07:44 AM
toy4paw toy4paw is offline
toy4paw is starting off with a positive reputation.
NEVER NOTICED THE COFFEE CAN ON MINE. MAYBE I NEED TO LOOK HARDER.
NOT REAL SURE WHAT IT WOULD DO EITHER
Old 09-18-2003, 06:35 PM
RawPower's Avatar
RawPower RawPower is offline
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
Are you talking about the Compressor? It is almost always black, and mainly runs the AC. I also believe that it switches your 4x4 into gear when engaged on older models.
Old 07-05-2007, 10:03 PM
gagodc gagodc is offline
gagodc is starting off with a positive reputation.
Ive seen what he is talking about It has vacuum lines attached to it one comes from the main vacuum tree on the firewall the other goes to the cruise control its like a vacuum storage can and it does look just like a large tin can
Old 07-05-2007, 11:08 PM
tbone91 tbone91 is offline
tbone91 is starting off with a positive reputation.
I've seen the can on my 91 diesel and gasser Fords too. It's a little smaller than a coffee can, but larger than a can of beans... I always assumed it was for vacuum storage during hard acceleration when a gas motor has almost no vacuum.
Old 07-05-2007, 11:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Same thing on a diesel.
Vacuum storage to run the cruise control, heater vent control, C 6 automatics and brake booster.
Some use a small ball looking reservoir instead of the coffee can type.
I think you are refering to the soup bowl removal.
A naturally aspirated motor may have an air cleaner top that looks like this.
Ford installed the soup bowl to make the intake quieter, but it hurts performance.
So the thing to do is remove the soup bowl.
Your Banks turbo should have taken care of that already, but I have seen a Banks air cleaner lid that looked almost like the picture.
I would not remove the coffee can, braking may suffer when you have less vacuum in reserve.
Old 07-05-2007, 11:44 PM
my 85 has both the ball and the can. What is the best way to remove the soup bowl?
Old 07-05-2007, 11:59 PM
You can use a 4" grinder with a cut off wheel.
Several people have used a sawz-all with a metal blade.
Some E series motors had a flat top air cleaner lid if you have a salvage yard close by.
How ever you cut it off, you have to be careful you do not cut the top of the lid and cause an air leak that would be bypassing the air filter.
Old 07-06-2007, 12:44 PM
matts156's Avatar
matts156 matts156 is offline
matts156 is starting off with a positive reputation.
I recommend strongly against removing the coffee can. It's not a performance upgrade, and I agree with the earlier post that speculated a possible confusion with the "soup bowl".
Removing the "coffee can" will do away with your vacuum reserve. If you use your brakes and then find that you need to stop suddenly again right away (as in pulling out of an intersection and then stopping to avoid an accident), you might find that you have a hard pedal and won't be able to stop your truck as quickly. Having a vacuum reserve is crucial to preventing loss of boost to your brakes.
Old 07-06-2007, 01:06 PM
shorthair shorthair is offline
shorthair is starting off with a positive reputation.
if it does nothing else removing the soup bowl will allow removing the air filter LID alone. did mine with an air chisel too less than 2 imn's to do it use care not to gouge any holes in the lid.
Old 07-06-2007, 01:13 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
On a gas engine, you will find the vacuum resevoir(coffee can) hooks to the the vacuum tree through a check valve. The HVAC vacuum line also hooks beyond the check valve with a tee connection to the coffee can. This is so when you pull a long hill in a gas engine, and you start losing vacuum, the check valve closes and the resevoir starts supplying the vacuum to the HVAC to keep the air vents from switching back and forth when the vacuum does go low.
I haven't seen a diesel setup yet, but I would imagine if it has a check valve in the line, and is tee'd into the line going to the HVAC, that it has the same purpose-to stablize the vacuum controls in the HVAC system.
Old 07-06-2007, 11:48 PM
Diesel vacuum is supplied by a pump that is belt driven.
Pulling a hill does not affect the level of vacuum.
Try stopping one with no vacuum to run the brake booster.
You may want to install a second coffee can after the first stop without a vacuum assist on the brakes.
Vacuum is a bad thing in a diesel engine intake manifold.
It means the air filter is way to dirty.
Pounds of pressure in the intake manifold is a good thing.
1988 4.9 f150 vacuum "coffee can" jaltman1984 1987 - 1996 F150 & Larger F-Series Trucks 5 03-04-2014 07:49 PM
Coffee can RIKIL 1987 - 1996 F150 & Larger F-Series Trucks 18 09-12-2011 09:22 AM
Egr & coffee can delete and o2 sensor move FossenRacing 1987 - 1996 F150 & Larger F-Series Trucks 7 10-08-2010 09:30 AM
EGR valve sensor Volvo92906 1987 - 1996 F150 & Larger F-Series Trucks 36 07-28-2009 01:37 PM
Driver Side Coffee Can darknight1028 Ford Inline Six, 200, 250, 4.9L / 300 8 06-09-2009 12:44 PM
Tags
1972, 1995, 351, 87, can, coffe, coffee, compressor, do, engine, f150, ford, thing, truck, trucks, vehicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
