Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-15-2003, 09:21 PM
jdnelles jdnelles is offline
jdnelles is starting off with a positive reputation.
stalling when driving/trouble starting
Please Advise,
Just bought a 94 explorer for my wife....have only had it about a week....95,000 miles. It runs great when it is running, but she has had a problem with it shutting down on her while driving...and then it won't want to start for awhile there after. It acts as if it is not getting fuel...a couple of times when I got it to start right after dying...it would idle real low and would not respond to pumping the accelerator....then after awhile it would act fine. Any thoughts? Fuel filter? Fuel pump relay? (these two are the cheapest and I hope the answer) Fuel pump? ignition system? Additionally the check engine light is on. Help is appreciated.
thanks, Jim
  #2 (permalink)
Old 09-16-2003, 09:34 PM
seagull369 seagull369 is offline
seagull369 is starting off with a positive reputation.
Very cute. Well, there certainly can be many reasons why this is happening (some that you mentioned).
My dad's Jeep had the EXACT same problem as you described. The mechanic replaced the fuel pump and the problem never showed itself again. I dont know if the mechanic replaced other parts relating to the pump (such as relay etc) or more than what was necessary, but you might want to start taking a look at the fuel system. Start with replacing the filter, check out the relay, then start focusing on the pump.
__________________
Ken 1994 Mazda B-4000 4.0 litre
  #3 (permalink)
Old 09-16-2003, 11:39 PM
mrshorty mrshorty is offline
mrshorty is starting off with a positive reputation.
See what trouble code(s) the computer is storing and causing the CEL to come on. See www.dalidesign.com/hbook/eectest.html for instructions.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #4 (permalink)
Old 09-27-2003, 05:35 PM
Billy177 Billy177 is offline
Billy177 is starting off with a positive reputation.
i would change pcv,fuel filter,plugs,wires,air filter,clean iac and maf and clean fuel injectors
  #5 (permalink)
Old 12-24-2003, 09:31 AM
PONY99 PONY99 is offline
PONY99 is starting off with a positive reputation.
Sounds like a dying fuel pump. Had that same problem in my Mustang GT. If you get in the vehicle and first turn the key to on listen for a buzz, thats the fuel pump starting and priming. If after you drive for a while you can hear an audible whiny buzz then the vehicle stops, its definitely the fuel pump. Thats what I experience on my Mustang. Leave it sit for about 5 minutes and she'll start right up.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
