F-150 5.0 timing adjustment - Ford Truck Enthusiasts Forums
Old 10-11-2001, 10:00 PM
JonHRhodes JonHRhodes is offline
JonHRhodes is starting off with a positive reputation.
Ok.. I admit. It is my first time to do this. I have a Haynes manual but, it is unclear. My 1996 F-150 5.0 has fuel injection and I want to check the timing and the book says to remove the spout plug? I know about the old type vaccuum advance hoses but mine does not have one. I disconnect the only connector on the distributor and the truck won't fire off. Where is this mysterious spout plug?
Thanks in advance
Jon
Old 10-11-2001, 11:44 PM
buzzer buzzer is offline
buzzer is starting off with a positive reputation.
The spout plug in in a separate harness with two wires up near the test plugs that are on the drivers cowl near the hood hinge. You will recognise the spout plug as having two wires that have what looks like a plastic jumper on it.You start the truck remove this spout plug which jumps the two wires together and that puts the truck on basic timeing which is what you need to set the timing.When you are done replace the plug and the ecm takes over then for the timing advances.You should at least buy a chiltons manual at an autoparts store as it will help you with other repairs also.
Old 10-12-2001, 08:22 AM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
Lost spout connector! Sampson767 1987 - 1996 F150 & Larger F-Series Trucks 7 11-04-2015 04:19 PM
1995 f-150 wont start starfriend 1987 - 1996 F150 & Larger F-Series Trucks 3 10-29-2013 04:02 PM
Runs better with SPOUT connector removed?? tonkyman 1987 - 1996 F150 & Larger F-Series Trucks 46 08-20-2013 01:09 AM
back to my old SPOUT issue bnb29 Electrical Systems/Wiring 7 04-24-2011 04:44 PM
1994 F150 5.8L Timing Question Boldt 1987 - 1996 F150 & Larger F-Series Trucks 19 01-08-2003 12:51 PM
Tags
1987, 50, 50l, 92, 96, adjust, adjuster, adjustment, advance, check, distributer, f150, ford, timimg, timing, timming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
