Spark Plug not seated/E150
No.2 cylinder spark plug on my straight-6 went in crooked, I'm pretty sure. It makes the "tick-tick" sound while running now. It's such a tight space there that I can't even see the hole where it goes in. Is there any compound I can put around the threads of the spark plug to seal it when I take it out and reinstall it or just what do you do for something like that? The engine is in my '90 E150 and it has over 272,000 miles on it so far. It's really difficult to get to that spark plug!
Thanks! Jack '90 E150 300ci
'95 F350 4WD CREWCAB 7.3L POWERSTROKE
'79 F250 360ci
'79 F250 360ci
Don't know about a sealer but you might want to use a thread chaser or sparkplug hole cleaner to clean up the threads if you cross threaded them tight. The bad part is that if you can't see into that area, it might be a Beach to do this properly. You might try one of the various antisieze or temperature resistant thread locking compounds. Be sure to read the lable, some compounds won't work. I use Permatex antisieze, but I am not sure how well it would seal the threads.
Good Luck,
Jim Henderson
Good Luck,
Jim Henderson
