6 into 2 Headers
6 into 2 Headers
I have a set of 6 into headers that will fit a 300 straight six, I would love to install a set of dual exhaust and use these however I am worried about the carb icing up in the cooler weather and winter.
Does anyone have any experience with this?
Is there a way around not having the heat from the stock manifold to heat the carb and still avoid icing?
Craig ( Lisle Ontario )
Hows about this. after you install the headers, take the old heat riser and notch it to fit around them. would that work? i know that i drove my '83 302 last winter without the riser and it iced up on me a couple of times. Made it interesting though because the throttle stuck at wide open goin accross a bridge. was doin 90 in a 50 by the time i got off the other side!! just an idea i had. let me know what you think.
You know what my thoughts would be on fixin it Quadiquizm, are you close to a junkyard? this item, especially if self removed, should be very cheap. you can keep the original mounting and there won't be any welds to grind off if necessary. Thats just what i would do, but maybe your local junkyard rip you off, i don't know. Like i say, just a thought.
cfrazier77
09-11-2009 10:38 AM
GHog
11-28-2004 01:43 PM
