tilt nose update
tilt nose update
I finally got around to hooking up my camera to my computer ( it's only taken me about a year to get to it ) and I updated my gallery for the installation of the tilt glass front end. Some of you may be interested in how it was done and I hope it may help others in solving their own problems that occur with this type of modification. The nose now fits good and the body lines and gaps are also good. The latch system works well and it securely latches the front end. The release is in the cab and is cable actuated. Now it's on to another area of this never ending project.
tilt nose update
I got my latches from Rocky Hinge Co. out of Ohio. Website www.rockyhinge.com. Nice people to deal with, by the way. The release cable was taken from a Honda and simply shortened. A rod connects the two latchesand is adjustable. The adjusters were made from small aluminum cable clamps that are usually crimped to braided cables. In my case I bought 1/8 rod and clamps from Home Depot then cut the rod to length, and drilled and tapped the clamps for set screws,also bought at Home Depot. The clamps were set to release both latches at the same time when the cable is pulled. The pins were just bolted to the support that I glassed into the front end. A little careful measuring and fitting will determine the location of the latches and pins.
on
tilt nose update
Jim,
very nice job... I had the same fit problem with a 53 hood... I noticed that your hood and fenders are seperated ??? you do that or do the F-1s come that way ??? I also like your latch answer...but the 53 firewall is recessed more than that.
Guess I could work something else out similar to that... Mine is on the back burner right now... actually it's on a rolling cart on its nose in the garage.....
why don't you contact Fairlane and ask if they want to buy their mold... theirs sure dont work !!!
later John
later John
tilt nose update
I am sure that the latches could be spaced out from the firewall by fabricating some sheetmetal boxes if necessary. The basic shape of the Fairlane front end remained the same. My biggest problems were the arch of the hood across the cowl,left rear portion length of the fender andside fit of hood area on the left side. I had to section about 3/4" off the left rear section of the fender and put cuts along the left hood sides to bring it in closer to the cowl. This was in addition to removing the Fairlane brace under the hood and fabricating my own. My fit problems were simalar to the ones encountered by John on his 53. We have each solved the fit problem a little differently for our unique situations but I think it demonstates some of the problems encountered when using this type of front end. For what one of these front ends cost you would expect a perfect fit. I still like the tilt front end idea but would probably think twice before buying another from this company. I have spent many hours getting the fit right on this particular front end. Any of you other guys out there using these front ends? If so did you encounter these type of fit problems or were you satisfied with the fit as supplied from the company?
