"Alumaloy" Idea?
"Alumaloy" Idea?
Originally posted by fatfenders
Anyway, I hope I don't discourage folks here from posting new ideas.
fenders,
Not at all!
I hope you know I was laughing when I typed my reply.
One of the things I enjoy most about this forum (besides all the awesome people here, great trucks, and all the great resources) is the clowning around and great sense of humor that everyone has. Please don't ever feel bad about busting my chops. I enjoy being part of it!
"Alumaloy" Idea?
I have been holding back on this post as some of the words that will appear can/will be insiteful to some of those that hang out here.
There are several brands of epoxy putty that are very useful around the garage/house. These putties come in a roll with the two parts of the mixture situated insuch a way that you either cut or break off as much as you need for the job and then knead them togeather. They come in all flavors, general purpose, steel, copper, aluminium, wood and concrete.
All are fast setting, very durable and highly chemical resistant I have used them under water, patched gas/diesel tanks, and machined the stuff.
Now the stuff that will get some of ya'll excited: The brands that I have used are Leapfrog and Pig Putty, and No the shouldn't be used as the name implies.
http://www.newpig.com/en_US/main.jht...Repair+Putties
"Alumaloy" Idea?
You might try pewter (low melting point and fairly inexpensive)and can be cast in silicone rubber molds. Use 100% silicone caulking and build up your mold in thin layers to a thickness of 1/4 to 3/8" , allow each layer to set up overnight, be sure to use a good release agent on the original piece( several heavy coats of wax should work). Silicone is good to about 600 degrees and pewter melts at about 500. You can melt the pewter with a torch just make sure that whatever you are using for a crucible can take the heat, I use a ladle like you use for casting lead bullets. I have used this process to cast small sculptures and it is nearly foolproof.
keukabound
18
05-24-2020 08:54 PM
