Threading shifter for aftermarket handle
I am sure that the shift **** is a press fit for both the trans and the transfer case. There are ***** out there that have a set screw instead of being threaded. You can remove the shift boot by removing the four screws in the trim ring and then remove the shifter lever from the shifter stub shaft. This is done by undoing the nut and putting it on the opposite side and tightening it back up to pull the tapered pin loose. You then undo the nut and pull the pin and then you can remove the shift lever to take it inside to a vise to hold it while threading it if required. I wonder if there are replacement shift levers available or trucks like there are for Mustangs which use the same trans. Would a mustang shifter work on a truck , probably too short though. I know there are some that have a better shift throw stop built into them as well to prevent the lever from traveling too far. Your local parts/sped shop should be able to help you on this .
on my truck it was just vertical spline and the shift **** i bought was held on by allen key set screws so i just had to ream the inside of the shift **** out to fit it onto the shifter. It might be diff for auto shifters but if its for a stick id suggest buying a **** with set screws
i just glued mine in a old truck i had with j/b weld, in my 79 i pulled the plastic off the end and it glued on there too.
trying not to get too far off topic but a shifter isnt always a shifter, in my 79 i took one of those solid metal skull heads and tapped threads in it. put a large bolt in it and it made a one of a kind hood ornament the young punks can hang on and isnt going anywhere.
Hi,
On my 87 F-150 with a manual tranmission I had a tapered shaft, and the factory **** kept on falling off, making difficult at best to shift.
I since have installed a pool ball (#3) onto the shaft bb drilling the ball in increments until I believe was 9/16 at the base. I then used that epoxy putty inside the ball and smacked it on with a plastic hammer. Its been on for the past eleven years with no problems
seaves46
12-03-2004 03:26 PM
run2car
11-26-2004 12:31 AM
