expedition axle ratios - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-12-2003, 11:24 PM
daa daa is offline
daa is starting off with a positive reputation.
Thanks for the replies to my previous post. I just purchased this 99 e/b 5.4l and i'm very excited about it what a beautiful vehicle. Anyways, I bought this espy with the idea of towing my 19 foot Champion bass boat. I am concerned about the tow capacity after reading some of the posts. It seems I dont have the factory tow package like i thought. The vehicle is a 2wd has a factory hitch, load leveling rear suspension and 16 inch rims, but the door panel axle reads 17, which i've learned is a 3.31 non-limited slip axle. What kind of towing ability can I expect, and what is the difference between a limited slip and non? Also where would the trans cooler be if so equipped?
Old 09-13-2003, 02:28 AM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
You appear to have the package. The optional towing package did not spec a particular axle ratio for 1999. On 1999 4x2 Expeditions, the rear LLS could only be obtained in concert with the optional towing package. Take a look at the 1999 Expedition Ordering Guide found over at www.xpedition.net
Having an Expedition with a semi-automatic 4wd system doesn't give me much insight into the kind of towing experience you will have, but I would be a little concerned about traction if you have to pull your boat up a slippery, steep boat ramp on a regular basis. Make sure you have a good tire on the vehicle. When tire replacement time rolls around, I would look at an all-terrain tire with a more aggressive tread than the typical SUV all-season tire.
My 1999 Ford Expedition workshop manual confirms your translation of the axle code. A limited-slip differential is intended to divert power to the wheel that has the most traction. A non-limited slip differential tends to work in the exact opposite manner.
If you have some loose change tucked behind the cushions of your sofa, this may not be a bad time to have a limited slip setup installed. You may also want to consider installing a lower gear ratio at that time if your trailer is on the heavy side.
Probably the best thing to do is tow your rig a few times and see how it does before you start making changes.
Any idea how much your boat/trailer and the gear you stow in the boat while towing and launching weigh?
Old 09-13-2003, 10:37 AM
philrush philrush is offline
philrush is starting off with a positive reputation.
I think you will be OK.
I have pulled my old boat with a Nissan Pathfinder, so Im sure you will be OK with your rig.
your boat will wiegh in around 3000-3500 lbs when loaded.
I would be careful not to pull in overdrive tho, and would also keep an eye out for steep ramps.
I have seen some concrete ramps at Smith Mountain Lake in Va, that almost REQUIRE 4wd once they get wet
Just make sure you have a tranny oil cooler. Go under the hood and peek down thru the radiator shroud.
You should see a small "radiator" mounted to the front of your main radiator.
phil
Old 09-13-2003, 02:41 PM
tsdrallyer tsdrallyer is offline
tsdrallyer is starting off with a positive reputation.
Your axle ratio is okay for the rig you have. The two most important things you need to consider if and when you encounter wheel slip on old seldom used ramps, are A: tires and B: limited slip in that order.
Premium wet weather, softer compound tires like Pirelli, Michelin or Bridgestones will probably be enough. If it isn't then consider getting a limited slip mounted in the rear differential. That will cerainly take care of it. I used to launch and retrieve 3K lbs of sailboat from the back end of a 3K lb Ford Faimont two door... but it had Pirelli P77s and they stuck like glue to wet ramps while wild and wooly looking pickups and SUVs with aggressive treads spun their wheels and got nowhere.
Simple getting all terrain tires is not enough, they must have a good soft wet weather compound with lots of sipes. Open agressive treads just mean less rubber on the ramp to give you traction.
If you have 17" wheels, then it looks like a choice between Bridgestone Dueler Revos and Michelin LTX M/S or Crossterrains.
You can see which one I bought below.
Oh, and one final tip... always have a full tank of gas when you are launching or retrieving... it puts more weight over the rear wheels.
Hope this helps.
Old 09-14-2003, 09:36 PM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
You'll be OK towing that little boat around and won't have any problems with the ramps unless their covered with ice or algae.
I don't have the tow package on my Expy, but generally a transmission cooler is mounted on or very near the front of the radiator....it'll look like a little mini-radiator.
Old 09-16-2003, 08:59 AM
Petrol's Avatar
Petrol Petrol is offline
Petrol is starting off with a positive reputation.
I think you would be much better served with a 3.55 or 3.73 Limited Slip if you can afford to change it out but like the previous post says, tires are very important . . . a good soft rain tire can't be beat.
Old 09-18-2003, 10:42 AM
jrangel jrangel is offline
jrangel is starting off with a positive reputation.
anyone have a list of axle codes and could you post them please
Old 09-18-2003, 11:42 AM
Look for the vehicle certification label on the driver's door. This label will say "MFG. by Ford Motor Company" at the top, and will list front and rear GAWR, tire pressures and will show a bar code.
Below the bar code find a grouping of terms including AXLE. Directly below this word is the axle code:
17 = 3.31 non-limited slip
19 = 3.55 non-limited slip
H6 = 3.73 limited slip
H7 = 3.31 limited slip
H9 = 3.55 limited slip
Old 09-18-2003, 06:44 PM
here is a link to "most" axle codes.
for some reasonthe H6 code isnt listed though.
http://www.drivetrain.com/Fordtrkratio_posidata.html
Old 07-24-2011, 02:30 PM
PA RK Classic PA RK Classic is offline
PA RK Classic is starting off with a positive reputation.
1999 Expy Eddie Bauer Help Needed (Gear Ratios)
I have a 99 Espy EB 4x4 with a 5.4 l engine. The owner's manual lists the axel ratios for this set-up w/ 16 inch tires as either a 3.31 or a 3.73 which yields a 6,400# or 7,900# trailer respectively.
My door tag lists an H9 Axel (3.55 gears)...which is not listed in the owner's manual.
I am trying to determine my tow capacity but do not see any reference to a 4x4 w/ 5.4 l engine and 3.55 gears.
My trailer hitch states 8850# and 885# tongue weight.
Is the hitch tag what I go buy for this or is there some other way to determine this?
I do not have auto load-leveling and it does have auto AWD.
Any help appreciated.
Old 07-24-2011, 03:48 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Your's could be a late 1999 build with some of the 2000 specs. in it. Because the 2000 owner's manual states: 4x4, 5.4L with 3.55 and 16 in. tires has a GCWR of 13,000 lbs. and a trailer weight range of 0-7,400 lbs
Old 07-24-2011, 05:51 PM
Thanks
I was wondering why I couldn't find anything. So 7400 it is. Thanks again!!!
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 08:11 PM
3.55 Elect VS 3.31 Non-Limited Slip noserider 2015+ F150 56 02-09-2016 08:07 AM
Tech Folder Randallman 1999 to 2016 Super Duty 3 05-22-2011 11:03 PM
1966 Ford non limited slip to Limited slip/posi notmmrw1 1961 - 1966 F-100 & Larger F-Series Trucks 4 08-10-2007 11:42 AM
Non-Limited Slip Axle m 1997-2006 Expedition & Navigator 5 11-20-2002 08:32 PM
Tags
2005, 4x4, axle, boat, code, codes, expedition, f150, ford, gear, h6, lake, mountain, ramps, ratio, smith
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
