1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
do all super dutys have the same bolt pattern?
Old 09-11-2003, 08:46 PM
rebelbob's Avatar
rebelbob
rebelbob is offline
i was wondering if all super dutys have the same bolt pattern for rims?is it 99 that they changed the bolt pattern from the standard one on ford truck?thanks
Old 09-12-2003, 12:58 AM
hughesm1's Avatar
hughesm1
hughesm1 is offline
That is correct, the 99 and newer models have a 8x170mm bolt pattern. There fore, rims from 97 and older trucks won't fit.
Old 09-12-2003, 05:38 PM
wolfmanagh's Avatar
wolfmanagh
wolfmanagh is offline
The E series still use the same bolt pattern, they havn't changed them yet.
Old 09-14-2003, 09:38 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
That was 7 bolt wasn't it?
Old 01-14-2009, 01:45 PM
joelsutter's Avatar
joelsutter
joelsutter is offline
8x170 or 8x6 3/4
I have a lifted 2000 X and i have been dealing with alot of headaches. I bought a set of 35" tires on 22" rims 8X170 of course because thats what i am supposed to have. I could noe get them to fit i told the place that i bought them at that they must have sold me the wrong rims. After they told me they didnt i checked my spare tire bolt pattern to the new rims and what do you know they were the same. I then tried to put my FORD factory spare on and that did not fit either. I heard that ford had a weird 8X 6 3/4 bolt patern floating around could this be what i have. Any help would be great. Thanks Joel
Old 01-14-2009, 04:07 PM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
The 99 F250 Light Duty had 7 bolt hubs/wheels. 1999+ Super Dutys (and derivatives like the E350 & Ex) should be 8 x 170mm. Pre 1999 should be 8 x 6.5" (like the Chebbies & Dodges). I've never heard of an 8 x 6-3/4" pattern.
Old 01-14-2009, 04:10 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
2000 and on X had 8/170 you may have a late 99...I don't know!
http://www.okoffroad.com/editorial-boltpattern.htm
Old 01-14-2009, 04:31 PM
joelsutter's Avatar
joelsutter
ok so i found the actual spare from the X ford part # F81A-1015-AA. I called ford and gave them the part number and i was told this rim is for 2000 excursion only but still was a 8X170 bolt pattern. This rim fits.
an extra set of ford 8 lug wheels that are lying around are Part # F3TA 1015 MA (link) Set of FOUR Ford Wheels and Hub
Now when i got these i was told they were off a superduty ford 8X170. but they dont fit.
the Ultra 22" on 35" trxus are off a 1999 superduty and they do not fit my X.
i am so cunfused.
Now to make matters even more complicated i have a set of Weld Racing wheels 16.5 and they fit.
I need help, thanks Joel
Old 01-14-2009, 04:37 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
Bolt pattern for your excursion and superduty should all be the same...Super duty's had different back spacing on different years but the bolt pattern is the same....Unless someone messed with your X..
Old 01-14-2009, 04:48 PM
tazo's Avatar
tazo
tazo is offline
FORD - 05-up F-250/350 SuperDuty SRW (8-170mm B.C., 4.93" bore, hub centered) 1.41" offset
FORD - 99-04 F-250/350 SuperDuty SRW (8-170mm B.C., 4.93" bore, hub centered) .25" offset
FORD - 97-back F-250/350, 04-back E-250/350 SRW (8-6.5" bolt circle, 5.15" bore, stud centered) .25" offset
I got this from Rickson's web site.
Old 01-14-2009, 04:49 PM
joelsutter's Avatar
joelsutter
wow i finally figured it out from Accuride's website (fords steel wheel manufacturer.) the steel wheels i obtained and was told were 8X170 are actually pre superduty 8X6.5. The wheels i purchased and were told were 8X170 are actually 8X6.5. The steel spare PN is 8X170 from Accuride's website. what a waste of a day trying to figure this out. I guess i made it harder that it had to be.
thanks guys for all the help.
anyone want to buy a set of 35"on 22" ultra wheels 8X6.5, lol
thanks again joel
Fummins
03-23-2017 03:44 PM
bsneed
12-28-2016 01:29 PM
Redfridge
1997-2006 Expedition & Navigator
02-02-2016 09:04 AM
460/5
23
11-18-2009 04:49 PM
rebelbob
07-13-2003 11:03 AM
Quick Reply: do all super dutys have the same bolt pattern?
