do all super dutys have the same bolt pattern? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-11-2003, 09:46 PM
rebelbob rebelbob is offline
rebelbob is starting off with a positive reputation.
i was wondering if all super dutys have the same bolt pattern for rims?is it 99 that they changed the bolt pattern from the standard one on ford truck?thanks
Old 09-12-2003, 01:58 AM
hughesm1 hughesm1 is offline
hughesm1 is starting off with a positive reputation.
That is correct, the 99 and newer models have a 8x170mm bolt pattern. There fore, rims from 97 and older trucks won't fit.
Old 09-12-2003, 06:38 PM
wolfmanagh's Avatar
wolfmanagh wolfmanagh is offline
wolfmanagh is starting off with a positive reputation.
The E series still use the same bolt pattern, they havn't changed them yet.
Old 09-14-2003, 10:38 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
That was 7 bolt wasn't it?
Old 01-14-2009, 02:45 PM
joelsutter's Avatar
joelsutter joelsutter is offline
joelsutter is starting off with a positive reputation.
8x170 or 8x6 3/4
I have a lifted 2000 X and i have been dealing with alot of headaches. I bought a set of 35" tires on 22" rims 8X170 of course because thats what i am supposed to have. I could noe get them to fit i told the place that i bought them at that they must have sold me the wrong rims. After they told me they didnt i checked my spare tire bolt pattern to the new rims and what do you know they were the same. I then tried to put my FORD factory spare on and that did not fit either. I heard that ford had a weird 8X 6 3/4 bolt patern floating around could this be what i have. Any help would be great. Thanks Joel
Old 01-14-2009, 05:07 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
The 99 F250 Light Duty had 7 bolt hubs/wheels. 1999+ Super Dutys (and derivatives like the E350 & Ex) should be 8 x 170mm. Pre 1999 should be 8 x 6.5" (like the Chebbies & Dodges). I've never heard of an 8 x 6-3/4" pattern.
Old 01-14-2009, 05:10 PM
2000 and on X had 8/170 you may have a late 99...I don't know!
http://www.okoffroad.com/editorial-boltpattern.htm
Old 01-14-2009, 05:31 PM
joelsutter's Avatar
ok so i found the actual spare from the X ford part # F81A-1015-AA. I called ford and gave them the part number and i was told this rim is for 2000 excursion only but still was a 8X170 bolt pattern. This rim fits.
an extra set of ford 8 lug wheels that are lying around are Part # F3TA 1015 MA (link) Set of FOUR Ford Wheels and Hub
Now when i got these i was told they were off a superduty ford 8X170. but they dont fit.
the Ultra 22" on 35" trxus are off a 1999 superduty and they do not fit my X.
i am so cunfused.
Now to make matters even more complicated i have a set of Weld Racing wheels 16.5 and they fit.
I need help, thanks Joel
Old 01-14-2009, 05:37 PM
Bolt pattern for your excursion and superduty should all be the same...Super duty's had different back spacing on different years but the bolt pattern is the same....Unless someone messed with your X..
Old 01-14-2009, 05:48 PM
tazo's Avatar
tazo tazo is offline
tazo is gaining momentum as a positive member of FTE.
FORD - 05-up F-250/350 SuperDuty SRW (8-170mm B.C., 4.93" bore, hub centered) 1.41" offset
FORD - 99-04 F-250/350 SuperDuty SRW (8-170mm B.C., 4.93" bore, hub centered) .25" offset
FORD - 97-back F-250/350, 04-back E-250/350 SRW (8-6.5" bolt circle, 5.15" bore, stud centered) .25" offset
I got this from Rickson's web site.
Old 01-14-2009, 05:49 PM
joelsutter's Avatar
wow i finally figured it out from Accuride's website (fords steel wheel manufacturer.) the steel wheels i obtained and was told were 8X170 are actually pre superduty 8X6.5. The wheels i purchased and were told were 8X170 are actually 8X6.5. The steel spare PN is 8X170 from Accuride's website. what a waste of a day trying to figure this out. I guess i made it harder that it had to be.
thanks guys for all the help.
anyone want to buy a set of 35"on 22" ultra wheels 8X6.5, lol
thanks again joel
transmission bolt pattern? fred2001 1999 to 2016 Super Duty 3 11-22-2012 04:41 PM
Bolt Pattern on 2011 F-250 kirksii 1999 to 2016 Super Duty 7 04-27-2011 11:56 PM
Axles, Bolt Pattern, Quigley Conversion cyerger57 1999 to 2016 Super Duty 3 12-08-2005 08:31 AM
Engine to bell housing bolt patterns Captain_stuck Engine Swaps 3 11-05-2004 02:34 PM
Transmission to Bellhousing Bolt pattern? 1982fordf100 Clutch, Transmission, Differential, Axle & Transfer Case 3 02-02-2004 06:55 PM
Tags
1015, 8x170, 8x65, bolt, ca, diesel, e350, f250, f81a, f81a1015, f81a1015aa, fit, ford, fort, part, pattern, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
