rough idle no power backfires bad - Ford Truck Enthusiasts Forums
Old 09-11-2003, 11:30 AM
toyota1988 toyota1988 is offline
toyota1988 is starting off with a positive reputation.
Exclamation rough idle no power backfires bad
89 ford 300 4x4 4spd truck will start but runs rough backfires badd and smelling gas fumes ive searched for vacumm and exhaust not sure about the 300 inline six all my other fords are 302's so im new to this motor emission control and throttle body intake.. any help !lost....
Old 09-11-2003, 12:41 PM
68torino's Avatar
68torino 68torino is offline
68torino is starting off with a positive reputation.
I would check the timing, did this just occur or has it progressively gotten worse? Also I would check the codes.
Old 09-11-2003, 03:46 PM
stractor stractor is offline
stractor is starting off with a positive reputation.
Pull the dist cap and look for carbon tracks between the contacts in the cap. Look at the wires for cross firing, look at the plug wires at night in the dark with the engine running and see if you can see any arc's between the wires or to anywhere. If in doubt replace the cap and rotor and wires , can't hurt, if they are old.
stractor
Old 09-12-2003, 12:40 AM
paulfix's Avatar
paulfix paulfix is offline
paulfix is starting off with a positive reputation.
Maybe the plug leads are on the wrong plugs. Easy to mix up if you pull them all of at once
Old 09-12-2003, 08:13 AM
rikfish's Avatar
rikfish rikfish is offline
rikfish is gaining momentum as a positive member of FTE.
I had a similar problem with my 300 I6. Check the timing, and if it is off, remove the distributor and check the gear. Mine had sheared the pin holding the gear to the distributor shaft. Gear had rotated significantly, but the pin had stayed in place, held by a small burr, holding the gear to the shaft.
Of course, about the time I had ALMOST removed the distributor, the gear fell off and down into the pan....where it remains to this day.
Old 09-13-2003, 02:53 AM
fe8u fe8u is offline
fe8u is starting off with a positive reputation.
might check your intake gasket. I had two ports missing part of the gasket. ran like a piece of sh--, know runs perfect.
Old 09-18-2003, 07:23 PM
Smile rough idle no power backfires bad
yes the distributor cap was very burnt and the wires were counter clockwise instead of ckw. i replaced the cap&rotor relocated the plug wires and its running strong now. im use to looking for the worse first but these 300"s motors i here are pretty strong.thanks alot guys..
backfiring jake_c_19 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 04-02-2015 02:55 PM
Backfire and rough running efi 302 needing help JamesF-250 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 10-08-2014 11:07 AM
Need Diagnostic Help! siciliannightmare Ford Inline Six, 200, 250, 4.9L / 300 7 09-10-2014 09:55 PM
460 backfires thru carb after 40 miles XolieX Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 15 10-30-2005 04:56 PM
300ci runs great cold, backfires and dies after warm-up bobonut 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-11-2005 01:33 AM
Tags
backfire, f150, power, rough, running, slight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
