351 Engine Weight? - Ford Truck Enthusiasts Forums
351 Engine Weight?
Old 09-10-2003, 04:21 PM
randallc's Avatar
randallc randallc is offline
randallc is starting off with a positive reputation.
351 Engine Weight?
I am going to start on a new project and want to build myself an engine.
The problem is that I live in an appartment building and will be doing all the assembly on the deck. I will need to wheel the engine into the elevator and bring it up 4 floors.
The elevator says that the max capicity is 1200 LBS but it is also older so I dont want to stress it out too much.
How much does a 351 weigh? I am sure it is not 1200 LBS but I just want to know what the weight is before I start.
Thx
Randall
Old 09-10-2003, 08:39 PM
jopey jopey is offline
jopey is starting off with a positive reputation.
351 Engine Weight?
under 600 lbs.
Old 09-10-2003, 09:14 PM
Bill_Beyer's Avatar
Bill_Beyer Bill_Beyer is offline
Bill_Beyer is starting off with a positive reputation.
351 Engine Weight?
Old 09-11-2003, 04:59 PM
beartracks's Avatar
beartracks beartracks is offline
beartracks is starting off with a positive reputation.
351 Engine Weight?
Ah that brings back the good old days! Laying on my back in the snow and a puddle of gear oil while changing out a set of gears.
Old 09-14-2003, 12:39 PM
Ecuri Ecuri is offline
Ecuri is gaining momentum as a positive member of FTE.
351 Engine Weight?
I think I'd worry about the floor in the apartment more than the elevator! Not sure about apartments, but residential design calls for 40lbs per sq ft live load. A sheet of 3/4 ply might not be a bad idea to spread that load around on the floor under the engine stand.
First Long Haul with my EGOboost! PrinceValium 2009 - 2014 F150 20 08-09-2015 07:33 PM
351m timing adjusting cysneed 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 12-17-2014 08:42 AM
Max weight ratings / real numbers ? my996duc1 Toy Hauler Towing; Fifth Wheel & Bumper Pull 13 01-09-2012 07:08 PM
Towing Capacity Question pongolo Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 3 06-03-2010 12:14 PM
4.6 Liter - How much can I tow? leroys4wd 1997 - 2003 F150 14 02-01-2005 04:20 PM
Tags
1990, 1996, 351, 351w, 42, dies, engine, f150, ford, motor, tranny, truck, weigh, weight, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
