Clicking/cracking noise in front
Hello, my 93 AWD makes clicking/cracking noises at low speeds when I'm backing up & turning the wheel or starting to go forward. No high-speed noise or vibration. Would this be the half-shafts? If so, from reading an earlier post, I'm confused whether or not I need a special puller.
Thanks,
Biederboat
Thanks,
Biederboat
Another vote for ball joints. They can make some gawdawful creaking and cracking noises if they are going bad.
Lift one front wheel off the ground by jacking under the spring pocket on the control arm (keep the jack clear of the ball joint & grease nipple). Lifting this way takes the spring load off the ball joint.
Grab the tire at the 12 and 6 o'clock positions and rock the wheel top to bottom. Look for play in both the upper and lower ball joints. Also lift the tire straight up & down while looking for play.
If you have a ball joint bad enough to creak & crack, it'll be obvious which one is worn out.
Cheers,
Eric
Cheers,
Eric
biederboat
03-18-2010 08:31 AM
