Computer Chips & Tuners
460 chips?
Old 09-10-2003, 12:47 AM
llasalle's Avatar
llasalle
llasalle is offline
Question 460 chips?
Have I missed something? I do not see any chip referrences for the 460 (cid) or 7.5L.
Old 09-10-2003, 10:48 AM
MXRocker's Avatar
MXRocker
MXRocker is offline
460 chips?
I agree! I own 1997 F250 4x4 w/460. Auto. that tows a travel trailer. This particular vehicle needs more help than the rest! Yet there seems to be little info on it (Chip wise). I heard that the SChips 1715 will not work because of the port location/configuration? Now what? Thanks:)
Old 09-10-2003, 01:39 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
460 chips?
Any 1987-2003 Ford with an EEC-IV or EEC-V can be chipped, including the 460. The reason you don't see information for it is because less than 1 in 100 chips sold is for the 460. You can only cram so much information on a site before people don't read it at all because its too wordy.
A Diablo chip can be programmed for it.
Old 09-11-2003, 10:23 PM
llasalle's Avatar
llasalle
llasalle is offline
460 chips?
webmaster:
There must be a reason that on 1 in 100 chip sales is for the 460.
Is it hard to improve upon? What are the performance provements? Horse power? Torque? Fuel economy? In what driving conditions?
Old 09-11-2003, 10:38 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
460 chips?
The reason is because 90% of the chips sold are for vehicles 3 years old and newer. The other 10% is split among all the 1988-2000 applications. There just aren't many people with 460 V8s asking about chips, just as there aren't many with 302 V8s and 351 V8s asking about them.
The 460 gains roughly 24HP and 45 ft/lbs torque. You may pick up a couple of miles per gallon but it requires premium fuel. Works under all driving conditions at all RPMs and throttle positions.
Old 09-11-2003, 10:46 PM
llasalle's Avatar
llasalle
llasalle is offline
460 chips?
Wow!
I have to run premium (octane 91) all the time to avoid ping when towing -- I never use 5th gear towing. According to the owners manual, octane 87 is required. Here where I live at 5300 ft. elv., regular is 85.5, and the middle grade is 88. Most often when I am loaded heavy or towing heavy I run at higher elevations. Does this indicate an existing problem?
What does a Diablo chip cost? How difficult is the installation?
It just ocurred to me that I purchased that truck in November of '94 with 33k miles on it. It has always ran strong, and gotten good fuel economy (12-14mpg, 8.7 worst pulling a double). Is it possible thta it was already "chipped" when I bought it?
Old 09-11-2003, 11:00 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
460 chips?
If you're having to run premium with stock tuning something is wrong, could be any number of things. See if you're getting codes (not likely but its a start).
Cost is here: http://www.motorhaven.com/customer/home.php?cat=37
Installation is simple, just pull out the computer (we supply instructions), clean the grease off the connector and plug the chip module into it. Takes about 30 minutes.
Old 09-11-2003, 11:04 PM
llasalle's Avatar
llasalle
llasalle is offline
460 chips?
See my post to "460 Tuning". I have always had good performance and fuel economy.
I purchased the truck used, in '94 with about 33k Miles on it. Is it possible that it was already chipped?
Old 09-11-2003, 11:14 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
460 chips?
Doubtful. If it was chipped it would not run on non-premium fuel (would ping a lot, loaded or unloaded).
Old 09-11-2003, 11:40 PM
llasalle's Avatar
llasalle
llasalle is offline
460 chips?
I am a bit confused.
I do have to run premium to avoid ping under heavy engine load, even climbling mountain passes running empty.
Please note that as you increase in altitude, octane requirement decreases because of the lower atmospheric partial pressure of O2. That is, in my estimation why the oil companies can get away with downgrading regular to 85.5 and medium to 88. When I have ocassion to travel to low altitudes I find regular at 87, medium at 89 and premium at 91 or 92.
Were performance chips available before I bought my truck in November of '94. If so, how do you determine if you have one?
Old 09-15-2003, 09:06 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
460 chips?
If you're currently running premium then something else is wrong. Its unlikely that you have a chip installed. If you did it would ping all the time. Octane requirements go down for chips as you gain altitude. You can see the chip attached to the outside of the computer box if you have one.
Usaallday
06-21-2014 07:04 PM
maxell3655
13
06-11-2009 08:59 PM
ejstave
03-29-2008 02:32 PM
redneck1011
05-17-2004 04:47 PM
Quick Reply: 460 chips?
