How to Remove a Stick Shift? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-08-2003, 08:55 PM
wekims wekims is offline
wekims is starting off with a positive reputation.
Question How to Remove a Stick Shift?
97 Ranger 2WD 2.3L. Trying to do a clutch job. Can't even start right! The manual says to remove a bolt at the base of the stick and it should slide right off. Yeah!!!
First there was a nut on a bolt. The nut came off easy but nothing happened. The threaded bolt (with nothing to turn) stayed on. Tried PB with a vice grip to unscrew the bolt but no luck.
Then I unscrewed the shifter cover to the tranny and pried the shifter off. The whole shifter and cover came off from where it connects inside the tranny.
Is that how it should come off? The manual hints that the shifter slides off at the bottom and the cover stays on?
Any help would be appreciated. Thanks.
Old 09-08-2003, 09:35 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
No thats not the way, but since you have done that continue on. Take the nut and put it on the back side of the slide into the shift arm and screw it on, should pull the shaft out for ya.
If all else fails leave nut on back off a few threads and tap to loosen, dont hit hard or you will screw up the threads.
2000 F150 - 4 Wheel Drive Floor Shifter Stuck, Repair Write-Up killacal 1997 - 2003 F150 4 01-04-2016 05:40 PM
Automatic E40D Swap to 5 Speed (Mazda M5R2) Ztitan 1987 - 1996 F150 & Larger F-Series Trucks 52 01-25-2015 09:55 AM
F-250 manual transmission removal wwgk1980 1973 - 1979 F-100 & Larger F-Series Trucks 5 05-25-2012 04:44 PM
How do I "safely" remove ZF5 shifter cover Greenetruck 1987 - 1996 F150 & Larger F-Series Trucks 5 08-10-2011 06:25 PM
m5r2 shifter rebuild help !!! Fixed !!! fcmtnbiker 1987 - 1996 F150 & Larger F-Series Trucks 8 01-15-2011 11:12 PM
Tags
97, arm, f150, ford, remove, shift, stick
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
