96 Ranger headlamps
96 Ranger headlamps
I belive the 96 has the same headlights as my 94, lets start with the drivers side light, when your facing the light, on the left hand side there should be what looks like the end of a screw facing out twards the engine, if you notice, the end of the screw has a box end on it, if you can find a socket small enough give it a turn, this should move the light either up and down, or left to right, I think its left to right, the other adjustment is on the right hand side, its going to be alot lower than the one on the left was, it helps if you have a socket with a long handle, this should adjust the up and down movement of the light. remember, the screw on the right hand side is alot lower than the one on the right. Hope this helps, ~Peter
