7.3 Powerstroke Various Problems - Ford Truck Enthusiasts Forums
Old 09-08-2003, 02:14 PM
Ontime Recovery Ontime Recovery is offline
Ontime Recovery is starting off with a positive reputation.
We are a UK based recovery company with a couple of F-550's, one with various problems. Unfortunately being in the UK means we find it difficult to get technical help so hopefully you guy's can help us. The truck is a 1998 7.3 Powerstroke with an automatic transmission (4R100) with gearbox mounted PTO and Century Wrecker Kit. Problem 1 - Under 1000rpm the truck sounds like it has a dry bearing somewhere (we have looked everywhere!) is this normal? Problem 2 - Does this engine have hydraulics tappets if so are they adjustable? Problem 3 - Would the air conditioning pump still work if the system became discharged? Problem 4 - Does anyone know of a supplier of 19.5" Phoenix wheel trims with pop out centres for the front differential locks? Problem 5 - The vehicle sounds and feels like it has a wheel bearing fault but they all seem ok could it be the tyres (Firestone On & Off Road Tyres)?Any help would be gratefully received.
Old 09-08-2003, 02:57 PM
RRMike's Avatar
RRMike RRMike is offline
RRMike is starting off with a positive reputation.
Well on the wheel bearing issue I know they can go bad and not have play in them. It's these new sealed bearings. I've heard several reports of folks that jacked them up and couldn't find any play but the bearings were shot.
Old 09-08-2003, 03:31 PM
lostbuckaroo lostbuckaroo is offline
lostbuckaroo is starting off with a positive reputation.
The air conditioning pump will not work if the system becomes discharged. There is a sensor that will not allow the pump to activate if a low refrigerent level is detected.
Old 09-08-2003, 04:24 PM
Thanks people just need answers to the other 3 problems. Once again many thanks.
Old 09-08-2003, 07:16 PM
riverbedjed riverbedjed is offline
riverbedjed is starting off with a positive reputation.
I know alot of people hate those firestone tires. The way they ride and the way they wear. you should podssibly try a new tire mabye a nitto, or a bfg all terrain, I have bfg at's on my super duty and i love them!!
Ken
Old 09-08-2003, 11:42 PM
International Tech's Avatar
International Tech International Tech is offline
International Tech is starting off with a positive reputation.
hi there. For the 1st question i need a lil more info. Like under any load, 1000rpm's is low so is there any idle issues, what noises are you hearing? the 7.3 has hydraulic lifters and do not need adjusting ever as they are hydraulic. lemme know
Old 09-09-2003, 04:31 AM
The noise is apparent when the engine speed drops below 1000rpm (when ticking over or when slowing down to stop). Someone mentioned that this could be the main gearbox shaft?
Its difficult to explain a noise but it sounds something similar to a loose dry worn bearing running at speed!!!!!!! Also the truck seems to lack power on pull away, someone mention something about fitting a direct drive unit? Does such a thing exist?
Old 09-16-2003, 12:12 PM
Can anyone help with the remaining problems?
Old 09-17-2003, 01:10 PM
firststroke firststroke is offline
firststroke is starting off with a positive reputation.
I may be way off, but the ticking sound, could it be the torque converter? I owned my SD with a 4r100 for almost 2 years before I realized it was making a noise. I replaced it over the weekend and I keep thinking it died when I come to a stop. It sounded like a bolt in a coffee can.
Old 09-20-2003, 06:10 AM
The truck is fitted with a Muncie Power Take Off unit fitted to the gearbox has anyone had any problems with these?
Old 09-24-2003, 02:25 PM
Firststroke, what was wrong with the torque converter that you removed? We got the motor into the workshop yesterday and drained the oil on the torque converter, there is something rattling around inside the torque converter so it is coming out over the next day or two. Are the torque converters repairable? Does anyone know how much a new torque converter for a 1998 Ford F550 7.3 Powerstroke?
Old 05-21-2012, 11:19 PM
mofo3181964 mofo3181964 is offline
mofo3181964 is starting off with a positive reputation.
1999 ford 350 super duty 730 diesel
I have a question for anyone?..I need help.. my truck runs great but everytime i turn on the wipers it dies can someone help me with this?
Old 05-21-2012, 11:35 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
Quote:
Wow, old thread to dig up...
Anyway, sounds like a possible CPS(Camshaft Position Sensor) issue. Any chance you know if it has a parts store CPS in it?
Get one from Ford or international and try that first.
Old 05-22-2012, 12:04 AM
smithrock's Avatar
smithrock smithrock is offline
smithrock is gaining momentum as a positive member of FTE.
Yeah even if you did a search, the title doesn't tell you much about the problem. That FNG must have been searching forever!.
Old 05-22-2012, 12:40 AM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
T early convertors all made that noise. Some got replaced by ford, and most didn't. When you change it out it will sound completely different.. Parts house CPS tend to do that when the windshield wipers come on. Not all, but 50/50.
Chet
Cruising speed Ianrhall 1947 and Older Ford Trucks 2 11-08-2016 08:53 AM
F250's in the UK carlg1 1987 - 1996 F150 & Larger F-Series Trucks 7 10-07-2016 07:47 PM
F250 7.3 wheels & tyres thread SSSimon Australia Chapter 30 02-17-2016 04:18 PM
Tyre help for an Aussie WA F250 1999 to 2016 Super Duty 0 01-14-2014 07:35 AM
305/70/18 Mickey Thompson Baja ATZ - on 2004 F250 zimsoundz 1999 to 2016 Super Duty 0 05-15-2012 11:42 AM
Tags
2000, 73, 73l, axle, converter, f250, front, noise, powerstroke, problems, speed, ticking, torque, usual, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
