Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch, Transmission, Differential, Axle & Transfer Case
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-07-2003, 11:06 PM
bandit bandit is offline
Garage is empty, add now
bandit is starting off with a positive reputation.
Unhappy Parking Pawl Rod
I jumped out of my 68 F250 with a 390 C6 combo after my sunday cruise,heard a clickin sound,turned around to see my truck headin down the driveway.I managed to jump in and stop it before it made it to the street.I checked the linkage and it looked good.Then i removed the linkage and pushed on the shifting arm to see if it wasn't engaging into park but it was.Can i inspect/replace the Parking Pawl Rod after removing the Transmission pan?Remove Transmission from truck?
  #2 (permalink)
Old 09-08-2003, 08:53 PM
rclarke rclarke is offline
rclarke is gaining momentum as a positive member of FTE.
Parking Pawl Rod
You might find the broken part in the pan but the transmission will need to be removed and torn down if the park pawl is the broken part. Occasionally the clip that holds the pushrod/actuator to the shift link will break or come out. Thats an easy fix if you are lucky.
  #3 (permalink)
Old 09-11-2003, 12:59 AM
Parking Pawl Rod
Thanks rclarke.
I'll drop the pan and have a look at the shift link
area at the end of the rod.
  #4 (permalink)
Old 09-12-2003, 12:40 AM
archangel archangel is offline
archangel is starting off with a positive reputation.
Parking Pawl Rod
and pull the end housing to see if the parking gear and lever is still ok.
On some older transmissions I have seen a "C" clip holding the gear on the shaft, the newer one have the casting on the end of the splines holding it on, and the extension housing had a bump cast into it also for that reason.
If the "C" clip came off, the gear might slide backwards and miss the parking pawl.
Tags
01, 150, actuator, broken, bronco, c6, clip, expedition, f150, ford, park, parking, pawl, removing, replace, rod
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
