rear drum adjustment?
Should be a knock out oval slot or an ovel rubber plug on the inside plate of the brakes-- usually just under the axle tube. If you look in there you will see a "star wheel". Just a washer with allot of teeth on it connected to the adjuster. Take a screw driver and turn it ( not sure which way ) but if it doesn't tighten up soon then your going the wrong way. Get it snug then back it off one turn.
