pcv valve problems
Old 11-13-2001, 09:13 PM
mtfl1's Avatar
mtfl1
mtfl1 is offline
pcv valve problems
I have a 1990 f150 302 5.0.It runs ok for about 2 or 3 minutes
then starts to loape (rpms up down,up down ect.) I removed the pcv
valve from the valve cover and then removed the pcv valve from its hose.Now it runs excellent.I bought a new pcv valve and put it in and it runs awful again.So its not the pcv valve.Can any one tell me what the problem could be.It seems like the vacuum from the hose that the pcv valve is in is too high.Well Im thoughly confused.Any help would be greatly appreciated.thanks mike
Old 11-13-2001, 09:58 PM
pross's Avatar
pross
pross is offline
pcv valve problems
its probably your IAC contol valve, when you disconnect the pcv valve, it allows the engine to breath in air and probably idles faster.The IAC is the only way the engine gets air while idling. there's only 2 screws holding it onto the intake throttle body. There's a small sliding valve in there that can get carboned up. It must slide freely. Are you getting a check engine lite?
Old 11-13-2001, 11:17 PM
PAUL_2's Avatar
PAUL_2
PAUL_2 is offline
pcv valve problems
There is also a pcv filter located inside the air filter housing that could be causing the problem . Make sure all the pcv passages are clear of sludge etc .
Old 11-14-2001, 04:57 AM
mtfl1's Avatar
mtfl1
mtfl1 is offline
pcv valve problems
I just put(last saturday) a brand new 54.00 iac valve and that wasnt it.Any other suggestions.At least I've found something obviously wrong,which is half the battle.thank you very much mike.
Old 11-14-2001, 05:00 AM
mtfl1's Avatar
mtfl1
mtfl1 is offline
pcv valve problems
Thank you I'll check that tonight after work.thanks Mike
Old 11-14-2001, 09:04 AM
cwlo's Avatar
cwlo
cwlo is offline
pcv valve problems
b4hntn
1978 - 1996 Big Bronco
21
10-09-2018 03:53 PM
WB4IUY
Escape & Escape Hybrid
06-28-2014 10:50 AM
Binkowski
17
04-24-2014 07:30 PM
dan001978
07-12-2008 06:03 PM
BrianJ77
08-15-2003 09:45 PM
Quick Reply: pcv valve problems
