100,000 mile service - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 09-04-2003, 02:18 PM
expe00 expe00 is offline
expe00 is starting off with a positive reputation.
I have a 2000 Expedition 5.4 4x4 with 100,000 miles on her. Is there anything in particular that you would service at this point? Oil is changed every 5000 and trans oil every 45,000. Thanks for the help.
Old 09-04-2003, 02:58 PM
PaulC PaulC is offline
PaulC is starting off with a positive reputation.
Spark plug replacement is one service recommended at 100K. A time-consuming process. Expect a $300 bill from a dealership. One plug is notoriously difficult to remove (#4, the rearmost plug on the passenger side). Ask for the old parts back and make certain you receive eight of the same plugs. Sometimes the techs "forget" to remove ol #4.
As an aside, you should be changing the transmission and transfer case fluid every 30K. Have the differential fluids ever been replaced? Brake fluid flushed?
Essentially, 100K is a good time to renew ALL fluids in the vehicle if they haven't been replaced/flushed on a regular basis.
Old 09-05-2003, 03:53 PM
1999XLT's Avatar
1999XLT 1999XLT is offline
1999XLT is starting off with a positive reputation.
ALL Fluids........................Tranny,Diffs,Oil,Che ck Brake fluid color.....
Spark Plugs.........ALL OF THEM..........................
Air Filter...................
PCV........................
Fuel Filter................
Check all your hoses for a "Spongy" feeling........If so replace them......................
Also, OVERLOOKED BY EVERYONE IS THE GOOD OLD SPARE TIRE.........DROP YOUR SPARE AND INSPECT IT IF IT NEEDS REPLACING DO SO...........Make sure the cable system works, and Lube the cable system.
Old 09-05-2003, 11:39 PM
tyger25's Avatar
tyger25 tyger25 is offline
tyger25 is starting off with a positive reputation.
How bout the regular tires? Alignment? Wipers? Prety much look at everything, and replace everything that you think needs to be done, or everything that's within your budget. Definately get all the lubes and oils though.
4x4 Service Interval xr7gt390 2009 - 2014 F150 21 01-02-2015 09:14 PM
100,000 mile maintenance? GRB1 Expedition & Navigator 0 07-18-2013 08:01 PM
Racor or Motorcraft Saxon 1999 to 2016 Super Duty 14 04-01-2012 08:58 AM
100,000 mile service?? roverjoe 1999 to 2016 Super Duty 5 01-17-2010 07:52 AM
Mobil 1 VRC9170 Oil & Lubrication 27 03-20-2009 03:14 AM
Tags
06, 100000, 2000, 2002, 2003, 2006, expedioton, expedition, ford, lincoln, mile, navigator, service, tune, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
