Ticking sound when accelerating hard or soft. - Ford Truck Enthusiasts Forums
Old 09-04-2003, 12:35 PM
crashed13 crashed13 is offline
crashed13 is starting off with a positive reputation.
Unhappy Ticking sound when accelerating hard or soft.
I have a 94 F -150 2x4 with a 4.9L inline six with 78,000 miles on it.
When accelerating hard or lightly and going up hills it has a ticking sound like a diesel that's not real loud but drives you nuts after awhile. I was told by just friends it may be a sticky valve or a small exhaust leak.
Can't see it being those because the motor sound quite and smooth at idle and and even while revving in park. Cant find a exhaust leak because it dose not make the noise when idling.
The ticking seem to come more from the lower passenger's side when driving. I even tried High octane gas to see if its a fuel grade pinging issue but it did not seem to quite it down.
Any suggestions will be looked into believe me.
Old 09-04-2003, 01:56 PM
FordPerf300 FordPerf300 is offline
FordPerf300 is starting off with a positive reputation.
probably is an exhaust leak that only occurs when the engine is under load. The exhaust route goes right under the passenger side of the vehicle so that make it even ore possible that, that is the problem
Old 09-04-2003, 07:21 PM
cocot's Avatar
cocot cocot is offline
cocot is starting off with a positive reputation.
It is a leak from the air tubes that screw into the head, probably #6.
Old 09-05-2003, 04:02 PM
juju_49 juju_49 is offline
juju_49 is starting off with a positive reputation.
I had the same problem, and it was the air tube. It aint cheap to fix.
Old 09-06-2003, 03:28 AM
Quote:
If I just say "The F%*# with it" will it hurt anything?
Old 09-06-2003, 09:35 AM
jarrod316 jarrod316 is offline
jarrod316 is starting off with a positive reputation.
I had the same problem on my 95. It was the air injection tube #6. If you have access to a wire feed welder it is a cheap fix assuming the tube is not rusted out. Pain to take everything apart just to get to it. I took the whole rail off to fix it.
Old 09-08-2003, 12:09 PM
TallPaul's Avatar
TallPaul TallPaul is offline
TallPaul is gaining momentum as a positive member of FTE.
Sometimes hard to tell where a sound really is coming from. I had a ticking like that and it turned out to be a spark plug that was just a tad loose. Easy to check--if it wiggles, it's the culprit.
Old 09-10-2003, 05:51 AM
I agree paul, i had problems with loose spark plugs the first day after i bought my truck. 4 out of 6 of them were loose, and they were causing a ticking sound.
Old 09-10-2003, 11:42 PM
Prodigy223 Prodigy223 is offline
Prodigy223 is starting off with a positive reputation.
If everything else fails (spark plugs, air tubes, exhaust leak) check if your lifters are knocking.
Ticking noise Superdutystiller 1999 to 2016 Super Duty 3 05-07-2015 02:51 PM
77 F-150 351m ticking under load StinkyGringo 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-14-2015 09:26 AM
Please Help!! 2008 f150 5.4 ticking Problem. TrukProblemz 2004 - 2008 F150 5 02-10-2014 03:51 PM
How loud can an injector tick be? fishg92 1999 to 2016 Super Duty 10 01-04-2014 10:02 PM
5.4 Ticks, but only in gear acf6 1999 to 2016 Super Duty 23 10-26-2012 02:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
