Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-04-2003, 10:38 AM
cmelecci cmelecci is offline
cmelecci is starting off with a positive reputation.
Wet Interior
OK I'm an idiot. I left my F250 rear slider window open in a downpour. The rear seat and carpet is drenched. I vacuumed everything out with wet vac(in the rain!). Everything is still damp and windows fog up. The problem is, its still raining and I can't air out the interior. Any suggestions on how to dry it out? Does the carpet need to be removed?
Thanx in advance and I accept/expect the ridicule
Carl
  #2 (permalink)
Old 09-04-2003, 11:05 AM
jim henderson jim henderson is offline
jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE. jim henderson has a very good reputation on FTE.
Wet Interior
If you can get it under cover or in a garage it will help.
You might try a carpet cleaner since their nozzles and vacuum capability is much stronger than a wet vac. This will pull more moisture out of the rug. Then you might put a small electric room heater inside to warm things up. If you can leave the windows open, even better. You could also use a fan to circulate the air. If you are in a garage or under cover, leave the doors open and have a fan blowing into it.
Whenever you drive turn the defroster on and high fan. Or use the AC on high fan. The key is you want the AC compressor to be running(to condense out the moisture) and you want air circulation.
I can't laugh, been there done that.
Jim Henderson
  #3 (permalink)
Old 09-04-2003, 12:39 PM
Wet Interior
Thanx Jim,
My options are limited right now, the truck doesn't fit in my garage and we have a tropical storm coming ashore. It looks like rain for the next two days. Great idea using a carpet cleaner. Guess I'll continue vacuuming and soaking up with towels.
At this point I'm not sure if there is more water damage from the rain or my tears.
Thanx again
Carl
F250 SuperDummy
  #4 (permalink)
Old 09-04-2003, 05:25 PM
kittyhawk kittyhawk is offline
kittyhawk is starting off with a positive reputation.
Wet Interior
Did the same thing about 6 weeks ago.
Pulled it in my father In laws grage ( when he out of town)
Pulled up the door gaurds Lifted carpet and put an old tupper ware bowl that I cut the bottom out of on the tranny hump and put my box fan on high for around 36 hours It dried it all out.
Hope this helps.
Now I always shut ALL my windows even when there is not a cloud in the sky.
Dave
__________________
2002 F-250 CC 2x4 5.4 auto(wifes)
2006 Jeep Wrangler Umlimited(mine)
  #5 (permalink)
Old 09-04-2003, 09:03 PM
AegisSailor's Avatar
AegisSailor AegisSailor is offline
AegisSailor is starting off with a positive reputation.
Wet Interior
It happens to me all the time. Won't hurt nothing for a few days. Wait for the sun to come out and do it's magic.
__________________
Roger
Red 2004 F-150 4.6L 4WD Automatic
  #6 (permalink)
Old 09-05-2003, 01:41 PM
Wet Interior
Thanx again to everyone. I was able to remove rear seat and put it my garage to dry out via heat gun and fan. The carpet was lifted to dry under it, but strangely doesn't appear wet. I left some 1x1 lumber under sections of the carpet to allow it vent somewhat. I certainly do appreicate the input from everyone.
Carl
  #7 (permalink)
Old 09-11-2003, 06:19 PM
Derek96f150 Derek96f150 is offline
Derek96f150 is starting off with a positive reputation.
Wet Interior
rent and Rug Doctor or take it to a detail shop and get a shampoo. If that carpet stays wet long enough it is going to start to smell and then possibly start to rust your floor boards, however, thats if it is soaked badly.
  #8 (permalink)
Old 09-12-2003, 03:41 AM
bandit bandit is offline
bandit is starting off with a positive reputation.
Wet Interior
Try running a Dehumidifyer in it for a day or two.If you have access to one that is.A little carpet fresh couldn't hurt after.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
