78 F-250 Highboy 4x4
Hi, well I am sure this same question has been asked a lot but I am going to ask it again... I have a 460 block and I am rebuilding it, I went to put in my new crank bearings and the ones on the ends didn't fit SO now I am questioning the year of it I was told it came out of a 77 LTD but I am not so sure now the casting # is D1VE-A2B
if I got it right the # near the lifters is...
2H14
The heads are at Eastco getting rebuilt so I dont have the ##'s off those. Any help would be nice, Thanks
Travis
2H14
Travis
The V (3rd character) designation means it was designed for a Lincoln.
However, that engine could go into anything that had a 429/460.
The D1VE- meaning it was designed for a 71 but received some changes for 1973 because it was cast in August start of the 73 car production,& this would mean it was produced as a 460.
More than likely it came out of a full size car like a Lincoln,Thunderbird, Large Mercury.
No, they did cast them for annually projected production runs. That would have had to have been a giant warehouse. The DIVE casting number, with a few minor engineering changes, was used throughout that period for all 429/460 engines, as there were virtually no changes to the engines other than cam and c/r (pistons) from '72 through '78. Exceptions were dropping the CJ/SCJ, DOVE and DIVE blocks, after '71 and adding the PI, DIVE block, from '72-74. The PI became a standard production engine in '75.
I have heard a lot avout D0VE blocks and heard those are the Cobra and super Cobra jet blocks, what makes them differernt from the D1VE block? I am under the impression you can get a lot more horse power from a D0VE block over a D1VE block and that the heads on a D0VE block are a lot better. Can you use SCJ heads on a D1VE block? Sorry I know there are a lot of questions here and they are all mixed up...
The SCJ and some CJ engines had 4-bolt mains from DOVE and DIVE blocks cast with thick main bearing webs. Both blocks, can't remember the engineering codes on DOVE but DIVE is DIVE-AA, were machined as 2 and 4-bolt blocks.
All blocks, regardless of main bearings, will produce the same hp. The difference is the 4-bolt will live a lot longer when hp exceeds 650-700.
All 429/460 heads are interchangable on 429/460 blocks.
