Cummins in a Ford: I know im Sick
Hey everybody Im back again with another dimented conversion, why do what is already availible when you can be different. my 460 is getting old real old, a rebuild done correctly and the way i would want it would be in the 3000 dollar range. Now i can buy a complete rolled 33000 mile dodge 1996 Banks powered cummins 5 spd for pretty damn cheap from a friend. I can sell the 460, five speed, T-case BW not my 205 and all other mods and come out around 2400 the truck is about a thousand more and still sell some parts off the truck to pay the last bit. Now i don't want to hear about why im not doing the PS conversion, thats too easy please guys bear with me and let me know what you thoughts or experiences have been with this. I have researched it pretty heavily but thought that somebody may have seen some fabrication glitches that i might need to be aware of. Motor mount wise and K-member do measure up as long as i flip the driverside mount. Anybody interested write me ill keep you posted. By the way the Mass Air conversion kit is sold no negotiations, Mike has dib when she gets pulled out next month. Also any thouts on converting from Gas 6K tach to Diesel 4 K tach?
Thanks Dusty
Thanks Dusty
Just thought I would throw this in. This info is 100 percent true but some of you may not believe it.
The Cummings turbo diesel is actually made by ford. Did you really think that dodge could make such a good engine! Its true I have no idea why but I am correct.
Ok guys since your showing off i guess i better show off what im about to hack up LOL. Pastmaster i was wondering what motor you have in the tan truck? just curious, BTW does anyone know if i will need a fuel pressure regulator inline after my tank pumps for the diesel pump to function correctly? just a thought. The Green monster does have the Bronco 33 gallon rear tank in it now too.
Cya
Dusty
Cya
Dusty
[updated:LAST EDITED ON 11-Nov-01 AT 06:46 PM (EST)]Please don't take it personally pastmaster, i was just joshing you a little, i thought the big picture was cool. Gave me the idea to put my picture up too.
Do you know if the fuel pumps will fit into the gasoline tanks or if i will have to swap in the diesel tanks? As to the emissions If i get the oportunity ill swap cabs to a diesel cab and retitle since titles here do not include frames just the main cab. Otherwise as long as you declare diesel to the State of Montana they tax you accordingly and let it be. Thank you for the concern definately things i hadn't put enough thought into, Wouldn't have ever crossed my mind to look into using the diesel pumps. I spent all my time measuring and gathering info on the engine swap forgot about the fuel delivery.
Thanks
Dusty
Old Mass Air 460 Convert Info
https://www.ford-trucks.com/dcforum/80_96/4544_2.html
Thanks
Dusty
Cummins engines are not made or owned by either Ford or Dodge. At one time Ford owned a part of Cummins, but not anymore.
I sorry if my information was incorrect, but I am not sure if you are correct either, no disrespect. I am in an automotive mechanics course in moraine park tech college, my teacher informed us of the information about this subject. He used to work at a ford dealership for 15 years. I figured the in formation was correct, I’ll inform him what you said and I’ll get back to you. Ok
A mate of mine has a 6.5 litre 6cyl Izuzu turbo diesel and 5 Speed in his F150 so its all possible!
85 F350 4x4 250ci (soon to be 460ci running dual propane convertors and gas research mixers)
79 F350 351C 4speed
73 XA Coupe 351C 4v High port heads C6 9" 3.89 Close to 600HP To many other mods to list.
81 TF Cortina 250ci 5speed 4pinion LSD 13.2 sec Q-Mile (straight propane) 425 Impco mixer bolted onto 750DP Holley baseplate.
79 F350 351C 4speed
Alright everybody, here we go again LOL i took Pastmasters advise went up to Bigfork MT and inspected a Ford with a cummins in it. It's only an hour away from me. clean conversion very striaght forward ill post a picture from the ford+cummins web page just to show you all. Also when this begins in the next month i will give you all some updates and some photos. Also ill let you know what glitches i run into and how to by pass them if you are interested. Look out here comes another wacky conversion in the ford crowd. Picture will be posted as soon as my web server stops sending me debug notices about adding an attachment
So Far to give a list of what equiptment i have waiting for me since i bought it.
1- 96 Dodge 3/4 ton roll over
1-33K 5.9L cummins 12v
w/HP cam plate, banks twin ram intake & TST 16 cm2 turbo housing
1-NV4500
1-NP 205 ford Tcase
1-NV 241 T-case
3.55 geared dana 70 rear and
a coil four link dana 60 (to sell)
Dodge fuel Tank 25+ gallon inframe saddle tank and a few other odds and ends
Let me know your thoughts, the more feedback the less i will not evaluate
1-NV4500
1-NP 205 ford Tcase
1-NV 241 T-case
[updated:LAST EDITED ON 20-Nov-01 AT 09:55 AM (EST)]Hey Dusty,
If you have a 25+ gallon Dodge fuel tank... What are you going to do with the Bronco tank?
Bet you can guess what I am thinking... LOL
Mike
1995 F-350 460/E4OD with lots of stuff... Let me know and I'll tell you about it!
Mike
Dusty,
What is this a picture of.... It looks like an F150-F350 series truck... But I was unaware of this motor combination I thought the Cummings was in the F650 size trucks... You know SuperCrewzer's... If I brought one of those puppies home my wife would shoot me!
Mike
Same 1995 F-350...... Let me know I love to share!
