95 F-150 4.9L missing/bucking while cruising - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 05-04-2010, 04:25 PM
roLLitup roLLitup is offline
roLLitup is starting off with a positive reputation.
Thanks for the info wolfy. Unhooked and plugged the EGR hose yesterday evening and did not have any problem this morning leaving for work... but it doesn't happen every day anyway (did yours happen every morning or just sometimes?). I'll give it several days and see if my problem persists. If it does I'll put your advice to work and change the cap/rotor and see if that helps. Even if this does not fix my problem and I have to move on to the cap/rotor, the truck runs noticeably smoother, even idles a lot smoother, by removing and plugging the EGR hose.
A mech friend at work today seems to agree about cap/rotor. He expects there's moisture in the cap (eg. a cracked cap - which he said will probably be to small to see) and it only lasts a few minutes in the morning because the engine heat dries it out quickly after its running. After he mentioned that, it struck me that yesterday was the worst the problem has ever been and the night before we had near monsoon rains and flooding here in Ky. He says that's probably why it doesn't happen every day (there needs to be enough moisture in the air to cause the problem).
I would really love to get this problem fixed. I'll let you know what happens.
  #62
Old 05-05-2010, 09:39 AM
wolfy's Avatar
wolfy wolfy is offline
wolfy is starting off with a positive reputation.
Hey bud no problem. Your problem sounds identical to mine no joke!!! It was sometimes not every morning. And it was way way worse if it was high humidity or especially after it rains. And yes it was mostly in the morning!
I would for sure check into this. the cap and rotor are fairly cheap. See how much the parts are from FORD. Then see how much they are from Napa or ORielly's I have had nothing but trouble from the cheap junk from AutoZone. Just make sure its made in the USA. Like I said that Autozone junk lasted a few thousand miles. The parts I got from ORielly's were like night and day difference from the Autozone junk. My point in the rambling is don't get the cheap stuff. Spend the extra 5 bucks or so and get the better parts. Or you will more then likely be replacing the cheap stuff again soon.
Let me know how it turns out for ya. Oh and a look inside the cap is free. I bet its corroded and cooked in there. Mine sure was!!!
  #63
Old 05-19-2010, 04:34 PM
wolfy's Avatar
Any updates on this???
  #64
Old 05-22-2010, 05:05 AM
blueoval48 blueoval48 is offline
blueoval48 is starting off with a positive reputation.
Exclamation
ive got a 93 4.9 5speed with 206,000 that started missin an jumpin done all of this an didnt help so i got to pullin plug wires off an no.2 cly.is not fireing got fire on the wire so could it be the injector or a value dont know really stumped now!!!!
  #65
Old 06-01-2010, 06:40 PM
Sorry for the long absence wolfy, had to handle a couple of unexpected family issues... anyway...
You were correct that this would not solve my problem as it has happened several more times over the last few weeks (since trying the EGR fix). Today, I replaced the distributor cap and rotor button (with OEM Motorcraft parts). I cannot tell if anything is wrong with the old cap and rotor button by looking at it - I'm no mechanic - not even almost - but It doesn't look real dirty or anything, though the metal tips in the cap look somewhat worn/eaten away and the rotor button had a bit of black sludgy powder right on top of the metal point. I did not see any corrosion or burnt places.
I will watch closely over the next several days as we are scheduled to get some rain this week. I'll post back and let you know, hopefully, a lot sooner this time.
  #66
Old 06-01-2010, 10:11 PM
wolfy's Avatar
Hey no biggie!, just wondering if you got your problem fixed! Hope all is well with your family. Sounds like you are more of a mechanic then you think. if you can do this rotor and dist cap, then you are doing pretty good. From what you have described, that sounds like that could be the culprit. Mine also had that black sludgy powder on it.
Also when was the last time you did a spark plug change? And a spark plug wire change? You can at least change the plug wires! If you are not comfortable doing the plugs, then have a buddy that knows how help you out, or go to a local mechanic and get some quotes for them.
  #67
Old 06-09-2010, 07:37 AM
Have not had any problems since changing the cap and rotor. I believe the problem is solved - its been almost ten days. Appreciate the help wolfy.
  #68
Old 06-09-2010, 10:02 AM
wolfy's Avatar
awesome man!!! glad you got it fixed. I was lucky enough to have the same problem, hence why i actually knew how to fix it! Glad its all worked out for ya
  #69
Old 06-28-2010, 06:52 AM
topdogcustoms topdogcustoms is offline
topdogcustoms is starting off with a positive reputation.
Bump this is a good read
  #70
Old 06-28-2010, 12:33 PM
i did this mornibg but didnt have time to disconnect the battery it seems like its running better but i think its getting hotter faster maybe its just me but i think my mileage went up and i will post the results
  #71
Old 09-10-2010, 11:55 AM
wolfy's Avatar
Quote:
is your problem still gone? This thread is great, seems to have helped out a lot of people
  #72
Old 10-19-2010, 11:47 PM
Davis Davis is offline
Davis is starting off with a positive reputation.
I disconnected the EGR hose on my 1990 6 cylinder and now the stumble I have been chasing forever is gone. I was thinking that disconnecting the EGR make the mixture richer, and is easier to burn. By disconnecting the EGR is just covering up some other problem?
Some of you talk about a restrictor for the EGR, is this just a block off plate?
  #73
Old 10-20-2010, 04:43 AM
jrodtaclet jrodtaclet is offline
jrodtaclet is starting off with a positive reputation.
Davis
Hey Davis what is the EHG hose? thanks.
  #74
Old 10-20-2010, 09:07 AM
Quote:
Sorry I made a mistake it is the EGR hose.
  #75
Old 10-20-2010, 10:27 PM
So I pulled the hose off the EGR and it runs great. Has anyone replaced the EGR and it still ran great?
1991 f150 code 181 Lewis18 1987 - 1996 F150 & Larger F-Series Trucks 1 07-01-2016 09:22 AM
1991 f150 Bucking Issue awatts18 1987 - 1996 F150 & Larger F-Series Trucks 10 04-10-2016 08:59 AM
1987 F150 4.9L EFI rough idle runs rich Chris Braun 1987 - 1996 F150 & Larger F-Series Trucks 7 03-22-2016 01:03 PM
1995 F150 4.9l jerking and sputtering moosey78 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2016 04:38 PM
Cruise Control dead. Replaced almost everything and still no cruise? tigers2007 1999 to 2016 Super Duty 16 11-17-2012 05:49 PM
Tags
49, 49l, 89, 95, bad, bucking, cruising, cutting, egr, f150, ford, misses, missing, missingbucking, ranger, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
