95 F-150 4.9L missing/bucking while cruising - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 07-23-2014, 03:50 PM
AltonHargrave AltonHargrave is offline
AltonHargrave is starting off with a positive reputation.
My truck did this bucking for years. It is a 1992 F150 5.0L with automatic transmission. It turned out to be transmission shudder. It felt like it was going over railroad tracks sometimes. This is caused by old transmission fluid and is easily remedied by changing at least most of the fluid like I did in a filter change or buying one of the products out there that cures this. I think one of the most talked about is Dr Tranny's Shudder Cure. You just run it down the dipstick tube and there you go.
Don't try drinking this on a cold day. It is poisonous I am sure.
  #152
Old 07-23-2014, 04:30 PM
bobschultz bobschultz is offline
bobschultz is starting off with a positive reputation.
I should have mentioned that mine is a 5 speed. The bucking is at low rpm's like some of the others but I have changed my trans fluid awhile back.
  #153
Old 07-23-2014, 04:41 PM
I had a 1988 F150 with the 4.9L, a few years back and it started jerking. It turned out to be a bad TPS, throttle position switch.
  #154
Old 09-01-2014, 03:09 AM
spike150 spike150 is offline
spike150 is starting off with a positive reputation.
Hi I'm new to this site. But I have a little helpful advice . I too have had this same problem and tryed the EGR fix. This fix for me took care of the issue at the time but only to pop back up 6 months later. Now the truck has a start n stall problem. This only masks a deeper issue. Truck is a 91 f150 with 4.9l l6 and e4od auto trans
  #155
Old 09-01-2014, 03:38 AM
Need some help
My 91ford f150 4.9l l6 still has starting issues and I'm at ropes end here. It will start right up run perfect for 3-5 sec and then it sputters and dies. I can keep it running by fluttering the gas pedal a little.
This is what I've done so far:
New part include:
Complete distributor (brand is WPS)
Plugs ,wires + new coil
New o2 sensor
New MAP sensor
Starter and solenoid
(Long story timing was a little off)
Also checked fuel pressure (koeo 49psi koer 50psi and for unhooked 60 psi
Hope someone can help me out Thanks for the help in advance
  #156
Old 11-18-2014, 12:26 PM
Mike8087 Mike8087 is offline
Mike8087 is starting off with a positive reputation.
This truck I bought 1990 F150 4x4 has been setting for 3 years. I rebuilt the engine. I have tried every thing I can on my F150 300 6. New ideal air control valve, new idle control, plug and wires, disturber cap and rotor button. Throttle body gasket was broken and replaced it too. I took out every injector and cleaned them. I have a jerking and jumping in it about 1200 rmp driving me nuts mash it on down and it runs fine. It will idle some times and die some times. My smog pump locked up too. It was doing all this before the smog pump locked up. I will try plugging the egr line to see what happens. Thanks for the info.
  #157
Old 12-09-2014, 03:55 PM
sherLocke9's Avatar
sherLocke9 sherLocke9 is offline
sherLocke9 is starting off with a positive reputation.
I just put a new rebuilt 300 6 engine in my truck. 91 f-150 w/auto e4od trans. No smog in head. I've been having this same problem described here, the hesitation and jumping at 1/8-1/4 throttle, in all gears including reverse, smoothing out once opened up more. The old engine never did this, and I'm using all the same parts and sensors and stuff, and all brand new Motorcraft basic tune-up items (cap, rotor, wires, plugs, fuel and air filter, PCV valve). So it's been driving me crazy! When I unhook and plug up the vacuum line operating the EGR, the truck runs great! Pulls very smooth! But...
Before I go and make this restricter plate for the EGR valve, I'm wondering if the problem doesn't lie elsewhere, and the plate is a band-aid fix. It seems like many of you have had success with this modification, and for many thousands of trouble-free miles, but I'm still curious because there is something nobody has mentioned here - there is a solenoid/regulator between the vacuum tree on the intake manifold and the EGR valve vacuum tube - this solenoid/regulator is right below the EGR valve bolted to the driver's side of the valve cover. There are two of these here actually, and I'm referring to the one closer to the front of the engine. I am guessing (maybe I'm wrong) that this regulates vacuum strength reaching the EGR, so that the EGR can open and close by degrees, in response to engine needs. Or, does the natural variation in engine vacuum already do this, and this so-called solenoid thingy monitors this variation for the EEC for some other tangential reason? Could this be faulty and cause this trouble that we're all experiencing? When I was tearing my old engine down I noticed that this solenoid/regulator thing (I don't know what else to call it) was extremely brittle, and the wires coming into it are stuck in there, the plastic housing of the electrical connector shattering to pieces when I tried unplugging it. It's almost as if it got way too hot at some point, or is maybe just brittle with age. Since the wires seemed solid I let it be.
So who can weigh in on this thing? What does it do exactly? Could it be to blame? It is Ford part # FOTZ95459A, if that helps anybody understand what I'm referring to. I've heard it referred to as the TAB or TAD solenoid, and the Ford parts guy I spoke to on the phone called it the EVR solenoid, and said not every EFI engine has one. What is this thing? It clearly is related to the EGR valve, as the vacuum line controlling the EGR valve originates from it.
I'd really like to know more about all of this. I wouldn't be shocked, but I find it hard to believe that Ford would have incorrectly designed something as fundamental as an EGR system, and that restricting the EGR's opening into the intake is the best solution, even if it does work well and long.
Thanks ya'll for this great thread. It's got me looking in the right places! I'd be taking shots in the dark without all this info here.
-Paul
  #158
Old 12-09-2014, 09:15 PM
Randle's Avatar
Randle Randle is offline
Randle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant futureRandle has a brilliant future
If disabling the EGR smoothed the engine out, It's probably in the computer. There is three condensers in the computer that can go bad, most of the time you can visibly see a rupture or leak in them. They can be changed out if they haven't messed the board up. Making a restricter plate is just putting a bandaid on the real problem.
  #159
Old 12-10-2014, 09:47 AM
ZarK-eh's Avatar
ZarK-eh ZarK-eh is offline
ZarK-eh is gaining momentum as a positive member of FTE.
Quote:
-Paul
I believe those are used by the computer to activate the EGR and whatever else the computer controls. Electrical signal goes to it, and then it vents to atmosphere or supplies vacuum to whatever it controls (not sure of complete operation).
I would head to the junkyard and grab some of those connectors to replace them. They are not hard to pull apart. Pick out the red lock, and pick the lever thingie and then pull the wire out the back. maybe grab the solenoid(s) as well in case they are faulty, and any vacuum lines too.
I installed an aftermarket EFI on my 4.9l '78, and have investigated some of these as I do want to add the EGR function to my engine. EGR keeps the combustion process cool enough to prevent the nitrogen in the air from combining with oxygen. And on that matter, adding a Catalytic convertor too! ... yeah I'm a greenie
Last edited by ZarK-eh; 12-10-2014 at 09:54 AM. Reason: add bit about junkyard for spare parts
  #160
Old 12-10-2014, 12:38 PM
ZarK-eh's Avatar
  #161
Old 12-10-2014, 12:43 PM
if disabling the EGR valve is smoothing it out I would lean towards a fuel delivery problem start looking towards injectors I dealt with a similar issue with light hesitation and really bad bucking when you got on the gas pedal I put some injectors its from a 94 into into my 91 and it solve the whole problem just some food for thought.
and yes restrictor plate is just a band aid covers up the real underlying problem the capacitors in the computer there are problems with them but if they're not ruptured and they're not leaking they sould be fine
the solenoid you're talking about is a DPFE valve it allows the computer to control how much vacuum is applied to the EGR valve and make it toward open accordingly
also look at throttle position sensor and wiring going to it. It smoothing out when you give it more gas could mean you have a dead spot in the sensor.
  #162
Old 12-14-2014, 09:36 AM
sherLocke9's Avatar
Zark-eh, nice find on the video.
I went ahead and made a restriction plate for the EGR as a temporary solution. I can at least drive the thing for now, and it doesn't have spark knock anymore - it was doing that too, I forgot to mention. It drives and sounds great now! I used a 5/32" hole. I'm still wanting to get to the very bottom of this, especially if it's going to affect fuel efficiency. If I find anything helpful I'll update ya'll.
  #163
Old 02-14-2015, 02:42 AM
seapointejim seapointejim is offline
seapointejim is starting off with a positive reputation.
My 94 E250 4.9L has this bucking problem. I disconnected the green vacuum line to the EGR and it is a little better but still there. If I turn my keyswitch just past run toward start until the ABS light comes on (w/out engaging the starter) while driving the engine runs great. I have changed the key switch, the the thermostat, the distributor, the plugs and wires, and the throttle body gasket. I could be 100% wrong but the key switch trick seems to deliver a richer fuel mixture. I was going to pull the injectors but they must be fine if the van runs so well when the key is held.
Sidenote: I can hear a relay either pull in or drop out when I am driving and turn the keyswtich. Could there be some default start preset for fuel delivery? I'd like to fix the problem since holding the key while driving is a pain (although I have rigged a small pair of vice grips that make it easier)
  #164
Old 02-14-2015, 03:08 AM
do you have check engine light if so use paper clip method to pull codes or you scanner.also check fuel pressure and see what it's at.fuel pressure should be between 50 and 60 also have you tried changing your fuel filter yet might be a good idea and check your timingshould be 10 degrees before top dead center
  #165
Old 02-14-2015, 11:22 AM
Timing is good and yes I changed the fuel filter, but what I really want to know is:
What circuit/sensors am I bypassing by holding the keyswitch in the run position that makes the van run so good? I pulled the codes once before and will do it again. Im just so fed up with the thing that I just drive it like it is and hope that the bucking snaps the crank or something so I can just get rid of the whole nightmare. Another clue I noticed is that the van will run perfect when the engine is cold for about a minute or two. Go figure.
1991 f150 Bucking Issue awatts18 1987 - 1996 F150 & Larger F-Series Trucks 10 04-10-2016 08:59 AM
1987 F150 4.9L EFI rough idle runs rich Chris Braun 1987 - 1996 F150 & Larger F-Series Trucks 7 03-22-2016 01:03 PM
1995 F150 4.9l jerking and sputtering moosey78 1987 - 1996 F150 & Larger F-Series Trucks 5 02-12-2016 04:38 PM
barely any boost with cts monitor just installed ssmokey24 1999 - 2003 7.3L Power Stroke Diesel 3 07-15-2015 08:42 AM
6.7L Power Stroke, Tranny Runs Hot CREED250 1999 to 2016 Super Duty 3 07-10-2015 07:25 PM
Tags
49, 49l, 89, 95, bad, bucking, cruising, cutting, egr, f150, ford, misses, missing, missingbucking, ranger, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
